[petsc-dev] Do you have any suggestion in order to reduce my memory footprint?
Sun Oct 19 16:28:52 CDT 2014
   What do you get for -ksp_view ?
   You should very likely be using the -pc_type gamg if it is an unstructured grid problem or you are using your own mesh data structure or -pc_type mg if you are using the DMDACreate1/2/3()
   Barry
> On Oct 19, 2014, at 3:58 PM, Alletto, John M <john.m.alletto at lmco.com> wrote:
> All,
> I have a 64 bit linux machine with 256 GByte of memory and 30 processors.
> I am solving Laplace equations and the current solver I am using is taking every bit of memory I have available.
> Do you have any suggestions (such as changing precision or changing solvers or something else) in order to reduce my memory footprint?
> Many Thanks
> John
