[petsc-dev] Backend independent VecGetArray for GPUs
Karl Rupp rupp at iue.tuwien.ac.at
Sun Oct 19 08:45:52 CDT 2014
Hi Ashwin,
I'll add two functions returning the bare CUDA and OpenCL handles.
Best regards,
Karli
On 10/19/2014 03:42 PM, Ashwin Srinath wrote:
> Hi everyone
> Just wondering what the consensus is. I'm happy to submit a PR if
> someone can tell me what goes where!
> Thanks
> Ashwin
> On 18 Oct 2014 01:46, "Karl Rupp" <rupp at iue.tuwien.ac.at
> <mailto:rupp at iue.tuwien.ac.at>> wrote:
>     Hi,
>      >> > Why would we want this? The packages themselves
>     (CUDA/ViennaCL) only
>             expose
>             memory using these specific types. What use is it to wrap
>             these up in
>             a void * if you
>             just have to caste back down to use them. Isn't it better to
>             maintain
>             type-specific, and
>             type safe, interfaces for this stuff?
>             The biggest problem I faced was that there was no way to
>             access device
>             memory using petsc4py - since there is no equivalent for
>             VecCUSPGetArray. So returning a raw pointer may not be very
>             helpful
>             for C++/CUSP users (they already have a nice way to access
>             device
>             memory) but it would definitely make things a lot easier for
>             Python users.
>         To me it sounds like something that should be dealt with in the
>         library
>         that does the python bindings, not in PETSc itself. (...)
>     Unfortunately, this is not so easy: If the Python wrapper has to
>     take care of such a conversion, then it needs to use the *exactly
>     same build environment* as PETSc. The reason is that the CUSP and
>     ViennaCL types are C++ beasts, not having a defined ABI, so one can
>     run into all sorts of hard-to-debug problems when finally linking
>     libpetsc.so with the Python wrapper. If, however, PETSc provides
>     these low-level memory buffers, the Python wrapper can attach to a
>     well-defined ABI.
>     Best regards,
>     Karli
