[petsc-dev] Backend independent VecGetArray for GPUs
Ashwin Srinath ashwinsrnth at gmail.com
Fri Oct 17 16:05:19 CDT 2014
Thanks, Domomic
To be honest, I'm not sure where it would be appropriate. I'm just hoping
to see the functionality *somewhere* :)
On 17 Oct 2014 16:02, "Dominic Meiser" <dmeiser at txcorp.com> wrote:
>  On 10/17/2014 02:42 PM, Ashwin Srinath wrote:
> > Why would we want this? The packages themselves (CUDA/ViennaCL) only
> expose
> memory using these specific types. What use is it to wrap these up in a
> void * if you
> just have to caste back down to use them. Isn't it better to maintain
> type-specific, and
> type safe, interfaces for this stuff?
> The biggest problem I faced was that there was no way to access device
> memory using petsc4py - since there is no equivalent for VecCUSPGetArray.
> So returning a raw pointer may not be very helpful for C++/CUSP users (they
> already have a nice way to access device memory) but it would definitely
> make things a lot easier for Python users.
> To me it sounds like something that should be dealt with in the library
> that does the python bindings, not in PETSc itself. For example, it would
> be easy to write a wrapper functions like the following:
> void *getDevicePtr(Vec v)
>   void *ptr;
>   /* Use VecCUSPGetArray* or VecViennaCLGetArray*  to obtain device ptr */
>   return ptr;
> void releaseDevicePtr(Vec v, void *ptr)
>   /* Vec type specific code to release the pointer */
> What do we gain by having these wrappers in PETSc rather than in a
> separate library?
> Cheers,
> Dominic
>  Thanks!
> On Fri, Oct 17, 2014 at 12:09 PM, Dominic Meiser <dmeiser at txcorp.com>
> wrote:
>> On 10/17/2014 09:45 AM, Lisandro Dalcin wrote:
>>> On 17 October 2014 17:54, Dominic Meiser <dmeiser at txcorp.com> wrote:
>>>> Hi Ashwin,
>>>> Are you suggesting that `VecGetGPUArray*`  be added to the `Vec`
>>>> interface?
>>>> That might be problematic because these methods only makes sense for GPU
>>>> vectors. The interface of `Vec` would then be tied to the PETSc
>>>> configuration.
>>>>  These methods could be always available simply generate an error for
>>> non-GPU vector types.
>>  That's a possible approach. Barry, Jed, what's the preferred way of
>> doing this? Make base class interface wider or subtyping via compose and
>> query?
>>>  An alternative might be to compose the various `VecCUSPGetArray` and
>>>> related
>>>> methods with `Vec` objects. You could then query these methods and use
>>>> them
>>>> if available (and handle absence of the methods if needed, e.g. throw an
>>>> exception). This would be easy to add.
>>>>  Yes, however note that what we really need is a backend-independent
>>> way to get the RAW pointer to the GPU buffers. Right now we have calls
>>> to get the CUSP or ViennaCL array, to handle them you need C++ and
>>> depend on CUDA/OpenCL at compile-time.
>>>  In what sense should it be backend-independent? The method name should
>> be independent of the backend? Or the presence of the method should be
>> backend independent?
>> I don't see what your gaining by having the methods in Vec. You still
>> need to handle the error that occurs if you're dealing with a non-GPU
>> vector and you still have to know the vector type in order to interpret the
>> return value (device pointer vs OpenCL buffer).
>> Dominic
>> Dominic Meiser
>> Tech-X Corporation
>> 5621 Arapahoe Avenue
>> Boulder, CO 80303
>> USA
>> Telephone: 303-996-2036
>> Fax: 303-448-7756
>> www.txcorp.com
> Dominic Meiser
> Tech-X Corporation
> Boulder, CO 80303
> USA
> Fax: 303-448-7756www.txcorp.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141017/8c8d1356/attachment.html>
