[petsc-dev] Backend independent VecGetArray for GPUs
Karl Rupp rupp at iue.tuwien.ac.at
Fri Oct 17 14:05:54 CDT 2014
>    But you won’t want to have to create the CUSP or ViennaCL objects on the fly each time from the CUDA/OpenCL “raw pointers”?
why not? I can just 'wrap' an existing memory buffer for use with the
respective operations provided with the respective library. Note that
the cost of setting up such wrappers is negligible compared to the cost
of launching a CUDA or OpenCL kernel.
Best regards,
Karli
