[petsc-dev] Backend independent VecGetArray for GPUs
Lisandro Dalcin dalcinl at gmail.com
Fri Oct 17 10:45:12 CDT 2014
On 17 October 2014 17:54, Dominic Meiser <dmeiser at txcorp.com> wrote:
> Hi Ashwin,
> Are you suggesting that `VecGetGPUArray*`  be added to the `Vec` interface?
> That might be problematic because these methods only makes sense for GPU
> vectors. The interface of `Vec` would then be tied to the PETSc
> configuration.
These methods could be always available simply generate an error for
non-GPU vector types.
> An alternative might be to compose the various `VecCUSPGetArray` and related
> methods with `Vec` objects. You could then query these methods and use them
> if available (and handle absence of the methods if needed, e.g. throw an
> exception). This would be easy to add.
Yes, however note that what we really need is a backend-independent
way to get the RAW pointer to the GPU buffers. Right now we have calls
to get the CUSP or ViennaCL array, to handle them you need C++ and
depend on CUDA/OpenCL at compile-time.
Lisandro Dalcin
Research Scientist
Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
Numerical Porous Media Center (NumPor)
King Abdullah University of Science and Technology (KAUST)
http://numpor.kaust.edu.sa/
4700 King Abdullah University of Science and Technology
al-Khawarizmi Bldg (Bldg 1), Office # 4332
Thuwal 23955-6900, Kingdom of Saudi Arabia
http://www.kaust.edu.sa
Office Phone: +966 12 808-0459
