[petsc-dev] [petsc-users] petsc git next branch *is* unwound!
Nystrom, William David wdn at lanl.gov
Thu Oct 2 11:57:56 CDT 2014
On my local machine I have my master, bare git repo with the following config file
which Jed suggested a year or so ago:
% cat config
[core]
        repositoryformatversion = 0
        filemode = true
        bare = true
        sharedrepository = 1
[receive]
        denyNonFastforwards = true
[remote "origin"]
        url = https://bitbucket.org/petsc/petsc
        fetch = +refs/heads/maint:refs/heads/maint
        fetch = +refs/heads/master:refs/heads/master
        fetch = +refs/heads/next:refs/heads/next
[remote "artab"]
        url = ssh://ml-fey.lanl.gov/usr/projects/artab/users/wdn/repos/git/petsc
        fetch = +refs/*:refs/*
        mirror = true
And for my workflow, I stay in sync with the official PETSc git repo by periodically
executing the following command:
git remote -v update origin
And then I have various git clones from my master git repo where I do actual
work.
Do I need to do anything special now that the "next" branch has been unwound
with either my master git repo or my git clones?  In my master git repo, I have
3 additional branches - wdn_mods_next, wdn_mods_master and wdn_mods_maint
where I keep any of my own modifications to those respective branches.  And I
keep wdn_mods_next in sync with next by periodically executing the following
commands in a git clone with the wdn_mods_next branch checked out:
git pull origin next
resolve any conflicts and commit
git push origin wdn_mods_next:wdn_mods_next
So, if I do the following set of steps, should I expect them to work now that next
has been unwound?
1. cd to my master bare petsc repo
2. cd to my git clone of petsc with wdn_mods_next branch checked out
Dave
Dave Nystrom
LANL HPC-5
Phone: 505-667-7913
Email: wdn at lanl.gov
Smail: Mail Stop B272
       Group HPC-5
       Los Alamos National Laboratory
       Los Alamos, NM 87545
From: petsc-dev-bounces at mcs.anl.gov [petsc-dev-bounces at mcs.anl.gov] on behalf of Satish Balay [balay at mcs.anl.gov]
Sent: Thursday, October 02, 2014 7:38 AM
To: petsc-dev at mcs.anl.gov; petsc-users at mcs.anl.gov
Subject: Re: [petsc-dev] [petsc-users] petsc git next branch *is* unwound!
On Thu, 2 Oct 2014, Satish Balay wrote:
> petsc git users,
> If you are using next branch from git repository for integration or
> testing or working with it in some form - i.e if you have 'next'
> listed by:
> git branch
> Please delete and recreate it. i.e:
> git checkout master
> git branch -D next
> git checkout next
> From my check - the following feature branches are currently in next
> (not yet merged to master).
> Feature branch owners, please remerge your feature branches into to
> next - as you see fit.
BTW: Some of you might want to rebase/cleanup some of the feature branches
before merging to new next.
Also some of these feature branches are from pre-petsc-3.5 timeframe.
So a rebase to latest master might be something to consider. [if they
are still in line for a merge to master]
Satish
> $ comm -12 <(git branch -r --merged next | sort) <(git branch -r --no-merged master | sort)
>   origin/barry/cleanup-blaslapack
>   origin/barry/remove-dreal
>   origin/barry/remove-sidl
>   origin/barry/reuse-hwloc
>   origin/dmeiser/pullrequest-fix-cusp-bjacobi2
>   origin/dmeiser/pullrequest-remove-thrust-py
>   origin/jed/sr-driver4
>   origin/jed/vecghostgetvalues
>   origin/karlrupp/fix-viennacl-veccopy
>   origin/karpeev/fix-ksp-pcgasm
>   origin/knepley/feature-optcontrol-mg
>   origin/knepley/feature-plex-generator-args
>   origin/knepley/feature-plex-nasm
>   origin/knepley/fix-configure-petsc-dep
>   origin/knepley/fix-quadrature-order
>   origin/madams/sr-driver4
>   origin/maint
>   origin/mlange05/fix-gmsh-coordinates
>   origin/next
>   origin/paulmullowney/aijcusp-ellpack-fix
>   origin/prbrune/sf-examplefix
>   origin/prbrune/snes-ex19vtkoutput
>   origin/sarich/fix-tao-jbearing-bqpip
>   origin/shri/ts-dae-semi-explicit
>   origin/shri/ts-is-for-differential-variables
>   origin/shri/ts-powergrid
>   origin/stefano_zampini/matis-preallocation
>   origin/stefano_zampini/pcbddc-changeofbasis
>   origin/stefano_zampini/pcbddc_deluxe
>   origin/tisaac/feature-fe-geom-dim
>   origin/tisaac/plex-flexible-projection
> [obviously remove maint, next from the above list]
> The previous 'next' branch is currently available as 'next-oct-2014' -
> if you need it for any checks/debugging.
> Satish
