[petsc-dev] [petsc-users] petsc git next branch *is* unwound!
Jed Brown jed at jedbrown.org
Thu Oct 2 11:30:30 CDT 2014
Satish Balay <balay at mcs.anl.gov> writes:
> balay at asterix /home/balay/petsc (master=)
> $ git co next
> Switched to branch 'next'
> Your branch is behind 'origin/next' by 1963 commits, and can be fast-forwarded.
>   (use "git pull" to update your local branch)
> balay at asterix /home/balay/petsc (next<)
> Did old next get remerged into new next? Should I rewind it again?
https://bitbucket.org/petsc/petsc/commits/8c34c3ad2d52157761586f2bb6d4466aeb01b511
Barry should
$ git config pull.ff only
so he can stop making undesirable merges from upstream.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141002/164375f8/attachment.sig>
