[petsc-dev] [petsc-users] petsc git next branch *is* unwound!
Thu Oct 2 11:26:25 CDT 2014
balay at asterix /home/balay/petsc (master=)
$ git co next
Switched to branch 'next'
Your branch is behind 'origin/next' by 1963 commits, and can be fast-forwarded.
  (use "git pull" to update your local branch)
balay at asterix /home/balay/petsc (next<)
Did old next get remerged into new next? Should I rewind it again?
Satish
On Thu, 2 Oct 2014, Satish Balay wrote:
> Sorry - perhaps the instructions should have been:
> git checkout master
> git branch -D next
> git fetch
> git checkout next
> Satish
> On Thu, 2 Oct 2014, Barry Smith wrote:
> >   Why does it say "Already up-to-date.”  ? It’s like those things are already in next? Why isn’t it putting a bunch of stuff into next? Confusing
> >    Barry
> > ~/Src/petsc  next $ git checkout master
> > Switched to branch 'master'
> > Your branch is behind 'origin/master' by 3 commits, and can be fast-forwarded.
> > ~/Src/petsc  master $ git branch -D next
> > Deleted branch next (was 5fad734).
> > ~/Src/petsc  master $ git checkout next
> > Branch next set up to track remote branch next from origin.
> > Switched to a new branch 'next'
> > ~/Src/petsc  next $ git pull
> > From bitbucket.org:petsc/petsc
> >  + 5fad734...6e2aac5 next       -> origin/next  (forced update)
> >  * [new branch]      next-oct-2014 -> origin/next-oct-2014
> > Already up-to-date!
> > Merge made by the 'recursive' strategy.
> > ~/Src/petsc  next $ git merge barry/cleanup-blaslapack
> > Already up-to-date.
> > ~/Src/petsc  next $ git merge barry/remove-dreal
> > Already up-to-date.
> > ~/Src/petsc  next $ git merge barry/remove-sidl
> > Already up-to-date.
> > ~/Src/petsc  next $ git merge barry/reuse-hwloc
> > Already up-to-date.
> > ~/Src/petsc  next $ git push
> > Counting objects: 1, done.
> > Writing objects: 100% (1/1), 248 bytes | 0 bytes/s, done.
> > Total 1 (delta 0), reused 0 (delta 0)
> > To git at bitbucket.org:petsc/petsc.git
> >    6e2aac5..8c34c3a  next -> next
> > On Oct 2, 2014, at 8:16 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > petsc git users,
> > > If you are using next branch from git repository for integration or
> > > testing or working with it in some form - i.e if you have 'next'
> > > listed by:
> > > git branch
> > > Please delete and recreate it. i.e:
> > > git checkout master
> > > git branch -D next
> > > git checkout next
> > > From my check - the following feature branches are currently in next
> > > (not yet merged to master).
> > > Feature branch owners, please remerge your feature branches into to
> > > next - as you see fit.
> > > $ comm -12 <(git branch -r --merged next | sort) <(git branch -r --no-merged master | sort)
> > >  origin/barry/cleanup-blaslapack
> > >  origin/barry/remove-dreal
> > >  origin/barry/remove-sidl
> > >  origin/barry/reuse-hwloc
> > >  origin/dmeiser/pullrequest-fix-cusp-bjacobi2
> > >  origin/dmeiser/pullrequest-remove-thrust-py
> > >  origin/jed/sr-driver4
> > >  origin/jed/vecghostgetvalues
> > >  origin/karlrupp/fix-viennacl-veccopy
> > >  origin/karpeev/fix-ksp-pcgasm
> > >  origin/knepley/feature-optcontrol-mg
> > >  origin/knepley/feature-plex-generator-args
> > >  origin/knepley/feature-plex-nasm
> > >  origin/knepley/fix-configure-petsc-dep
> > >  origin/knepley/fix-quadrature-order
> > >  origin/madams/sr-driver4
> > >  origin/maint
> > >  origin/mlange05/fix-gmsh-coordinates
> > >  origin/next
> > >  origin/paulmullowney/aijcusp-ellpack-fix
> > >  origin/prbrune/sf-examplefix
> > >  origin/prbrune/snes-ex19vtkoutput
> > >  origin/sarich/fix-tao-jbearing-bqpip
> > >  origin/shri/ts-dae-semi-explicit
> > >  origin/shri/ts-is-for-differential-variables
> > >  origin/shri/ts-powergrid
> > >  origin/stefano_zampini/matis-preallocation
> > >  origin/stefano_zampini/pcbddc-changeofbasis
> > >  origin/stefano_zampini/pcbddc_deluxe
> > >  origin/tisaac/feature-fe-geom-dim
> > >  origin/tisaac/plex-flexible-projection
> > > [obviously remove maint, next from the above list]
> > > The previous 'next' branch is currently available as 'next-oct-2014' -
> > > if you need it for any checks/debugging.
> > > Satish
