[petsc-dev] petsc git next branch *is* unwound!
Thu Oct 2 08:16:46 CDT 2014
petsc git users,
If you are using next branch from git repository for integration or
testing or working with it in some form - i.e if you have 'next'
listed by:
git branch
Please delete and recreate it. i.e:
git checkout master
git branch -D next
git checkout next
>From my check - the following feature branches are currently in next
(not yet merged to master).
Feature branch owners, please remerge your feature branches into to
next - as you see fit.
$ comm -12 <(git branch -r --merged next | sort) <(git branch -r --no-merged master | sort)
  origin/barry/cleanup-blaslapack
  origin/barry/remove-dreal
  origin/barry/remove-sidl
  origin/barry/reuse-hwloc
  origin/dmeiser/pullrequest-fix-cusp-bjacobi2
  origin/dmeiser/pullrequest-remove-thrust-py
  origin/jed/sr-driver4
  origin/jed/vecghostgetvalues
  origin/karlrupp/fix-viennacl-veccopy
  origin/karpeev/fix-ksp-pcgasm
  origin/knepley/feature-optcontrol-mg
  origin/knepley/feature-plex-generator-args
  origin/knepley/feature-plex-nasm
  origin/knepley/fix-configure-petsc-dep
  origin/knepley/fix-quadrature-order
  origin/madams/sr-driver4
  origin/maint
  origin/mlange05/fix-gmsh-coordinates
  origin/next
  origin/paulmullowney/aijcusp-ellpack-fix
  origin/prbrune/sf-examplefix
  origin/prbrune/snes-ex19vtkoutput
  origin/sarich/fix-tao-jbearing-bqpip
  origin/shri/ts-dae-semi-explicit
  origin/shri/ts-is-for-differential-variables
  origin/shri/ts-powergrid
  origin/stefano_zampini/matis-preallocation
  origin/stefano_zampini/pcbddc-changeofbasis
  origin/stefano_zampini/pcbddc_deluxe
  origin/tisaac/feature-fe-geom-dim
  origin/tisaac/plex-flexible-projection
[obviously remove maint, next from the above list]
The previous 'next' branch is currently available as 'next-oct-2014' -
if you need it for any checks/debugging.
Satish
