[petsc-dev] does next model mess up our histories
Jed Brown jed at jedbrown.org
Thu Oct 2 00:07:56 CDT 2014
Satish Balay <balay at mcs.anl.gov> writes:
>>   Ok, if this can be documented and made as simple as possible? A
>>   tool to do it? If it requires remember several arcane git commands
>>   to do and remember the numbers of 5 merges you made, then forget
>>   it.
> Perhaps Jed will reply with a simpler 'single' command to do the
> revert all the merges from the feature branch - and an easy way to
> verify.
Nope, but I don't recommend these reverts because it makes it more
confusing to follow 'next' and to find which commit introduced a change
(when debugging something in 'next').  My preference is that in normal
workflow, you don't rebase/modify that which has been merged to 'next'.
If it's catastrophically wrong, then revert on 'next' and start over,
but if it just needs a tweak, do that on top of your branch.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141002/51ccecfd/attachment.sig>
