[petsc-dev] provider stuff in package.py
Wed Oct 1 08:30:06 CDT 2014
This used to be hacky code in blaslapack.py. I think I must have moved
it into a function - instead of inline hacks in there. (and updated
code as we saw breakages)
Perhaps at some point it was also needed by superlu [since it has some
blas equivalent - that should be skipping the optimization flags] - so
it got moved into package.py.
I guess we didn't do the alternative of identifying optimization flags
used - and strip them out - as we don't know what they can be.
Perhaps we could assume optimization flags are stored separately - and
look for it [instead of assuming] - I don't know..
Satish
On Tue, 30 Sep 2014, Barry Smith wrote:
>   This does not belong in package.py, where does it belong?
>   def checkNoOptFlag(self):
>     flag = '-O0'
>     if self.setCompilers.checkCompilerFlag(flag): return flag
>     return ''
>   def getSharedFlag(self,cflags):
>     for flag in ['-PIC', '-fPIC', '-KPIC', '-qpic']:
>       if cflags.find(flag) >=0: return flag
>     return ''
>   def getPointerSizeFlag(self,cflags):
>     for flag in ['-m32', '-m64', '-xarch=v9','-q64']:
>     return ''
>   def getWindowsNonOptFlags(self,cflags):
>     outflags = []
>     for flag in cflags.split():
>       if flag in ['-MT','-MTd','-MD','-MDd','-threads']:
>         outflags.append(flag)
>     return ' '.join(out flags)
>   And having a Windows and Not Windows functions for Opt flags in the API is disgraceful.
>    Barry
> On Sep 30, 2014, at 4:09 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Tue, Sep 30, 2014 at 4:00 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >   Matt,
> >     Can all the “provider” stuff in package.py like
> >   def getDefaultPrecision(self):
> >     '''The precision of the library'''
> >     if hasattr(self, 'precisionProvider'):
> >       if hasattr(self.precisionProvider, 'precision'):
> >         return self.precisionProvider.precision
> >     return self._defaultPrecision
> >   def setDefaultPrecision(self, defaultPrecision):
> >     self._defaultPrecision = defaultPrecision
> >     return
> >   defaultPrecision = property(getDefaultPrecision, setDefaultPrecision, doc = 'The precision of the library’)
> > be cleaned up/simplified/removed with the new BuildSystem model?
> > What was the original need for the provider stuff and is there still a need? If there is still a need can it be satisfied some other way. Is there every a need for a different provide for different packages? For example hypre gets one xxx provider and some other package gets a different xxxx provider.
> > The provider stuff is intended to support out-of-package ways to say something about the configuration. So we have an object
> > that can come from anywhere. The stuff around it just access the object automatically, instead of making the user pull it out and
> > reference it. I thought that was easier.
> > Do you want to just set a flag? I thought that was limiting, and duplicated information.
> > You can get rid of all this boilerplate code in newer version of Python. We have been
> > outlawing newer versions. If we reopen that discussion, I vote for autoinstalling Python
> > 2.7.
> >   Thanks,
> >     Matt
> >   Barry
> > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > -- Norbert Wiener
