[petsc-dev] please fix your bugs in next! error: 'SNESCompositeGetNumber' was not declared in this scope
Jed Brown jed at jedbrown.org
Tue Nov 25 17:20:52 CST 2014
Matthew Knepley <knepley at gmail.com> writes:
> Here is what I put in my config:
> [remote "patrick"]
> url = git at bitbucket.org:pefarrell/petsc
> fetch =
> +refs/heads/pefarrell/snes-composite-get-number:refs/remotes/pefarrell/snes-composite-get-number
This is rather complicated/involved if you have a lot of branches.  It's
also hard to remember which branches get updated from where.
> Then I do
>   git fetch patrick
> and then
>   git checkout next
>   git merge pefarrell/snes-composite-get-number
> So does your fetch line create a local branch?
Yes, it creates a local branch and then I push that local branch.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141125/e0a33ab2/attachment.sig>
