[petsc-dev] I hate nagupgrade
Jed Brown jed at jedbrown.org
Wed Nov 12 23:10:52 CST 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
>   I have switched the code to use urllib2 and time out after 2
>   seconds. I cannot test it because I don't have access to a flaky
>   connection which hangs when a network connection is attempted. (For
>   example if I disconnect from the network and use urllib it returns
>   immediately with an exception so the user sees no hang).
This looks useful.  ;-)
https://github.com/tylertreat/Comcast
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141113/1afff55f/attachment.sig>
