[petsc-dev] OpenCL contributor
Karl Rupp rupp at iue.tuwien.ac.at
Sat Nov 8 05:23:23 CST 2014
Hi Ken,
 > I am a PhD candidate in Heterogeneous HPC. I wonder if there's anything
> in particular that needs an OpenCL implementation in PETSc.
well, this is a fairly general question. Most OpenCL routines used in
PETSc are currently provided via ViennaCL. The only exception right now
is a finite element assembly kernel in PetscFE, which is implemented
directly in PETSc.
What's your background and previous experience? Is there anything you
are particularly interested in? Since you're a PhD candidate, I assume
you are working already on a certain topic. My recommendation is to
align any work on PETSc with your direct research agenda :-)
If you're looking for interesting research questions, I can think of a
few: For example, in ongoing projects some of us are working on
matrix-free applications of fine-grid operators in a multigrid context.
Jed has written some kernels based on AVX intrinsics, for which he'd be
very interested to see how they perform on GPUs. (Keep in mind that this
is certainly not a good place to start if you are rather new to OpenCL...)
Then there is still a lot of work left in the unification of how PETSc
deals with CUDA and OpenCL, so that they share a substantially larger
code base rather than being maintained separately. This, however, is not
about writing OpenCL kernels, but about deriving clever abstractions of
these two programming models and a seamless integration with the PETSc core.
If you really want to write and optimize OpenCL kernels, then the best
place to do so are preconditioners. A couple of GPU-accelerated
preconditioners have been proposed in the literature, but most of them
are based on CUDA. Also, most of them only ever showed up in the
respective paper and never made it into reusable library code.
As things are right now, don't bother with OpenCL on CPUs. You have much
better control over what is going on with a more conventional
programming model based on MPI+intrinsics plus much lower latency for
function/kernel calls.
Best regards,
Karli
