[petsc-dev] How to do LU factorization using SuperLU_dist and reuse the factorization?
Lulu Liu lulu.liu at kaust.edu.sa
Fri Nov 7 06:34:17 CST 2014
 I have to solve linear problems like Ax=b many times, and all of linear
problems have the same A but b is different.
My goal is to do A=LU using SuperLU_DIST,and then reuse this LU
factorization to solve Ly=b, Ux=y.
How to do it ? How to implement it more efficiently?
Thanks!
This message and its contents, including attachments are intended solely
for the original recipient. If you are not the intended recipient or have
received this message in error, please notify me immediately and delete
this message from your computer system. Any unauthorized use or
distribution is prohibited. Please consider the environment before printing
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141107/511abfb9/attachment.html>
