[petsc-dev] Running on KNC
Mark Adams mfadams at lbl.gov
Thu Nov 6 05:54:32 CST 2014
I am running on KNC and ex52 is sort of running, SuperLU runs on one
processor, but fails with this message on 2 procs.  The error message
suggests downloading superLU but you can see that it was downloaded.  Any
ideas?
03:19 bc0915 master ~/petsc/src/ksp/ksp/examples/tutorials$ make
runex52_superlu PETSC_DIR=/global/homes/m/madams/petsc
make: Warning: File `makefile' has modification time 19 s in the future
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: No support for this operation for this object type
[0]PETSC ERROR: Matrix format mpiaij does not have a solver package superlu
for LU. Perhaps you must ./configure with --download-superlu
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.5-25-g0ace994  GIT Date:
2014-07-07 14:50:15 +0200
[0]PETSC ERROR: ./ex52 on a arch-knc-opt named bc0915-mic0 by madams Thu
Nov  6 03:20:04 2014
[0]PETSC ERROR: Configure options --known-level1-dcache-size=32768
--known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0
--known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=8
--known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8
--known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8
--known-sizeof-size_t=8 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4
--known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --known-mpi-int64_t=1
--known-mpi-c-double-complex=1 --download-parmetis --download-metis
--download-superlu_dist --download-superlu --with-batch=1 --CFLAGS="-mmic
-mkl -fp-model precise" --CXXFLAGS="-mmic -mkl -fp-model precise"
--FFLAGS="-mmic -mkl -fp-model precise" --with-cc=mpiicc --with-cxx=mpiicpc
--with-fc=mpiifort --known-mpi-shared-libraries=1 --with-shared-libraries=0
--with-x=0 --with-debugging=0 PETSC_ARCH=arch-knc-opt
[0]PETSC ERROR: #1 MatGetFactor() line 3962 in
/chos/global/u2/m/madams/petsc/src/mat/interface/matrix.c
[0]PETSC ERROR: #2 PCFactorSetUpMatSolverPackage_Factor() line 16 in
/chos/global/u2/m/madams/petsc/src/ksp/pc/impls/factor/factimpl.c
[0]PETSC ERROR: #3 PCFactorSetUpMatSolverPackage() line 26 in
/chos/global/u2/m/madams/petsc/src/ksp/pc/impls/factor/factor.c
[0]PETSC ERROR: #4 main() line 209 in
/global/homes/m/madams/petsc/src/ksp/ksp/examples/tutorials/ex52.c
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
APPLICATION TERMINATED WITH THE EXIT STRING: Interrupt (signal 2)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141106/d1fcc773/attachment.html>
