[petsc-dev] TS ex11 crashing in parallel
Adrian Croucher a.croucher at auckland.ac.nz
Wed May 28 23:10:28 CDT 2014
hi
> You might have an old version of 'bfort' which does not know PetscFV
> is a type and thus creates
> incorrect bindings. I am sending you
> src/dm/dt/interface/ftn-auto/dtfvf.c so you can test, but
> you should
>   rm -rf $PETSC_DIR/$PETSC_ARCH/externalpackages/sowing*
>   rm -rf $PETSC_DIR/$PETSC_ARCH/conf/sowing
> and reconfigure using
>   ./$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
OK thanks, I just tried that, but no luck unfortunately- am getting the
exact same error message.
- Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
