[petsc-dev] TS ex11 crashing in parallel
Adrian Croucher a.croucher at auckland.ac.nz
Wed May 28 22:26:32 CDT 2014
On 29/05/14 14:48, Matthew Knepley wrote:
>     OK. There are a few other things missing or broken in the Fortran
>     interfaces that I will need at some point- e.g.
>     DMPlexConstructGhostCells(), PetscFVCreate(). At present I'm
>     writing my test code in C to avoid this issue, but will need to
>     get it going in fortran eventually.
> Okay,  I pushed those fixes to next.
Oh great, thanks very much :-)
Is there a trick to calling PetscFVCreate() from fortran though? The
test code snippet below errors out when I run it:
program main
! testing PetscFVM from fortran
   implicit none
#include <finclude/petsc.h90>
   PetscFV :: fvm
   PetscErrorCode :: ierr
   call PetscInitialize(PETSC_NULL_CHARACTER,ierr); CHKERRQ(ierr)
   call PetscFVCreate(PETSC_COMM_WORLD, fvm, ierr); CHKERRQ(ierr)
   call PetscFVDestroy(fvm, ierr); CHKERRQ(ierr)
   call PetscFinalize(ierr); CHKERRQ(ierr)
end program main
The error is:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Null argument, when expecting valid pointer
[0]PETSC ERROR: Null Pointer: Parameter # 2
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.4.4-5833-g396e404
GIT Date: 2014-05-28 21:50:40 -0500
[0]PETSC ERROR: ./testfvm on a linux-gnu-c-opt named des108 by acro018
Thu May 29 15:01:42 2014
[0]PETSC ERROR: Configure options --download-netcdf --download-exodusii
--with-hdf5-dir=/usr/lib --with-numpy-dir=/usr/lib/pymodules/p
ython2.7/numpy
--with-scientificpython-dir=/usr/lib/python2.7/dist-packages/scipy
--with-petsc4py-dir=/usr/local/lib/python2.7/dist-pa
ckages/petsc4py --download-triangle --with-fortran-interfaces=1
--download-ptscotch --download-chaco --download-ctetgen
[0]PETSC ERROR: #1 PetscFVCreate() line 1356 in
/home/acro018/software/PETSc/code/src/dm/dt/interface/dtfv.c
Cheers, Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140529/4ae25e2c/attachment.html>
