[petsc-dev] TS ex11 crashing in parallel
Wed May 28 19:30:46 CDT 2014
On Wed, May 28, 2014 at 7:18 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, May 28, 2014 at 6:39 PM, Adrian Croucher <
> a.croucher at auckland.ac.nz> wrote:
>> hi
>>> Yes,  I put an overaggressive check in. I will push the fix tonight.
>> Thanks. It looks like there is a problem (looks like a PetscProblem
>> problem, in fact)- I'm getting an error on compiling PETSc- my make.log is
>> below.
> I am always a step behind with the Fortran. Sorry about that. WIll push
> the fix tonight.
Okay, let me know if it works. I will finish going through the ex11 changes
by the end of the week.
What I hope is that you will be able to combine FVM and FEM in an example
soon.
   Matt
>   Thanks,
>      Mat
>> Cheers, Adrian
>> make[1]: Entering directory `/home/acro018/software/PETSc/code'
>> See documentation/faq.html and documentation/bugreporting.html
>> for help with installation problems.  Please send EVERYTHING
>> printed out below when reporting problems.  Please check the
>> mailing list archives and consider subscribing.
>>   http://www.mcs.anl.gov/petsc/miscellaneous/mailing-lists.html
>> Starting on des108 at Thu May 29 11:29:18 NZST 2014
>> Machine characteristics: Linux des108 3.2.0-4-amd64 #1 SMP Debian
>> 3.2.51-1 x86_64 GNU/Linux
>> Using PETSc directory: /home/acro018/software/PETSc/code
>> Using PETSc arch: linux-gnu-c-opt
>> PETSC_VERSION_RELEASE    0
>> PETSC_VERSION_MAJOR      3
>> PETSC_VERSION_MINOR      4
>> PETSC_VERSION_SUBMINOR   4
>> PETSC_VERSION_PATCH      0
>> PETSC_VERSION_DATE       "unknown"
>> PETSC_VERSION_GIT        "unknown"
>> PETSC_VERSION_DATE_GIT   "unknown"
>> PETSC_VERSION_(MAJOR,MINOR,SUBMINOR) \
>> PETSC_VERSION_LT(MAJOR,MINOR,SUBMINOR)          \
>> PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR) \
>> PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
>> PETSC_VERSION_GE(MAJOR,MINOR,SUBMINOR) \
>> Using configure Options: --download-netcdf --download-exodusii
>> --with-hdf5-dir=/usr/lib --with-numpy-dir=/usr/lib/pymodules/python2.7/numpy
>> --with-scientificpython-dir=/usr/lib/python2.7/dist-packages/scipy
>> --with-petsc4py-dir=/usr/local/lib/python2.7/dist-packages/petsc4py
>> --download-triangle --with-fortran-interfaces=1 --download-ptscotch
>> --download-chaco --download-ctetgen
>> Using configuration flags:
>> #define INCLUDED_PETSCCONF_H
>> #define ANSI_DECLARATORS 1
>> #define IS_COLORING_MAX 65535
>> #define STDC_HEADERS 1
>> #define MPIU_COLORING_VALUE MPI_UNSIGNED_SHORT
>> #define PETSC_UINTPTR_T uintptr_t
>> #define PETSC_HAVE_PTHREAD 1
>> #define PETSC_HAVE_SSL 1
>> #define PETSC_DEPRECATED(why) __attribute((deprecated))
>> #define PETSC_REPLACE_DIR_SEPARATOR '\\'
>> #define PETSC_HAVE_HDF5 1
>> #define PETSC_HAVE_TRIANGLE 1
>> #define PETSC_HAVE_SO_REUSEADDR 1
>> #define PETSC_HAVE_MPI 1
>> #define PETSC_PREFETCH_HINT_T2 _MM_HINT_T2
>> #define PETSC_PREFETCH_HINT_T0 _MM_HINT_T0
>> #define PETSC_PREFETCH_HINT_T1 _MM_HINT_T1
>> #define PETSC_USE_SOCKET_VIEWER 1
>> #define PETSC_DIR "/home/acro018/software/PETSc/code"
>> #define PETSC_HAVE_X 1
>> #define PETSC_LIB_DIR "/home/acro018/software/PETSc/
>> code/linux-gnu-c-opt/lib"
>> #define PETSC_HAVE_FORTRAN 1
>> #define PETSC_USE_ISATTY 1
>> #define PETSC_HAVE_SOWING 1
>> #define PETSC_SLSUFFIX "so"
>> #define PETSC_FUNCTION_NAME_CXX __func__
>> #define PETSC_HAVE_ATOLL 1
>> #define PETSC_HAVE_DOUBLE_ALIGN_MALLOC 1
>> #define PETSC_UNUSED __attribute((unused))
>> #define PETSC_FUNCTION_NAME_C __func__
>> #define PETSC_HAVE_C2HTML 1
>> #define PETSC_HAVE_CTETGEN 1
>> #define PETSC_HAVE_EXODUSII 1
>> #define PETSC_HAVE_VALGRIND 1
>> #define PETSC_USE_SINGLE_LIBRARY 1
>> #define PETSC_HAVE_CHACO 1
>> #define PETSC_HAVE_BUILTIN_EXPECT 1
>> #define PETSC_HAVE_PTSCOTCH 1
>> #define PETSC_HAVE_NETCDF 1
>> #define PETSC_DIR_SEPARATOR '/'
>> #define PETSC_PATH_SEPARATOR ':'
>> #define PETSC_HAVE_XMMINTRIN_H 1
>> #define PETSC_PREFETCH_HINT_NTA _MM_HINT_NTA
>> #define PETSC_Prefetch(a,b,c) _mm_prefetch((const char*)(a),(c))
>> #define PETSC_HAVE_BLASLAPACK 1
>> #define PETSC_HAVE_STRING_H 1
>> #define PETSC_HAVE_SYS_TYPES_H 1
>> #define PETSC_HAVE_ENDIAN_H 1
>> #define PETSC_HAVE_SYS_PROCFS_H 1
>> #define PETSC_HAVE_DLFCN_H 1
>> #define PETSC_HAVE_SCHED_H 1
>> #define PETSC_HAVE_STDINT_H 1
>> #define PETSC_HAVE_LINUX_KERNEL_H 1
>> #define PETSC_HAVE_TIME_H 1
>> #define PETSC_HAVE_MATH_H 1
>> #define PETSC_TIME_WITH_SYS_TIME 1
>> #define PETSC_HAVE_SYS_PARAM_H 1
>> #define PETSC_HAVE_PTHREAD_H 1
>> #define PETSC_HAVE_UNISTD_H 1
>> #define PETSC_HAVE_STDLIB_H 1
>> #define PETSC_HAVE_SYS_WAIT_H 1
>> #define PETSC_HAVE_SETJMP_H 1
>> #define PETSC_HAVE_LIMITS_H 1
>> #define PETSC_HAVE_SYS_UTSNAME_H 1
>> #define PETSC_HAVE_NETINET_IN_H 1
>> #define PETSC_HAVE_SYS_SOCKET_H 1
>> #define PETSC_HAVE_FLOAT_H 1
>> #define PETSC_HAVE_SEARCH_H 1
>> #define PETSC_HAVE_SYS_RESOURCE_H 1
>> #define PETSC_HAVE_SYS_TIMES_H 1
>> #define PETSC_HAVE_NETDB_H 1
>> #define PETSC_HAVE_MALLOC_H 1
>> #define PETSC_HAVE_PWD_H 1
>> #define PETSC_HAVE_FCNTL_H 1
>> #define PETSC_HAVE_STRINGS_H 1
>> #define PETSC_HAVE_SYS_SYSINFO_H 1
>> #define PETSC_HAVE_SYS_TIME_H 1
>> #define PETSC_USING_F90 1
>> #define PETSC_USING_F2003 1
>> #define PETSC_HAVE_RTLD_NOW 1
>> #define PETSC_HAVE_RTLD_LOCAL 1
>> #define PETSC_HAVE_RTLD_LAZY 1
>> #define PETSC_C_STATIC_INLINE static inline
>> #define PETSC_HAVE_FORTRAN_UNDERSCORE 1
>> #define PETSC_HAVE_CXX_NAMESPACE 1
>> #define PETSC_HAVE_RTLD_GLOBAL 1
>> #define PETSC_C_RESTRICT  __restrict__
>> #define PETSC_CXX_RESTRICT  __restrict__
>> #define PETSC_CXX_STATIC_INLINE static inline
>> #define PETSC_HAVE_LIBBLAS 1
>> #define PETSC_HAVE_LIBZ 1
>> #define PETSC_HAVE_LIBDL 1
>> #define PETSC_HAVE_LIBGFORTRAN 1
>> #define PETSC_HAVE_LIBLAPACK 1
>> #define PETSC_HAVE_LIBCRYPTO 1
>> #define PETSC_HAVE_LIBPTSCOTCH 1
>> #define PETSC_HAVE_LIBM 1
>> #define PETSC_HAVE_LIBSCOTCHERR 1
>> #define PETSC_HAVE_LIBTRIANGLE 1
>> #define PETSC_HAVE_LIBPTESMUMPS 1
>> #define PETSC_HAVE_LIBPTHREAD 1
>> #define PETSC_HAVE_LIBMPI_F77 1
>> #define PETSC_HAVE_LIBHDF5 1
>> #define PETSC_HAVE_LIBNETCDF 1
>> #define PETSC_HAVE_LIBMPI_F90 1
>> #define PETSC_HAVE_LIBX11 1
>> #define PETSC_HAVE_FENV_H 1
>> #define PETSC_HAVE_LIBEXODUS 1
>> #define PETSC_HAVE_LIBHDF5_HL 1
>> #define PETSC_HAVE_LIBRT 1
>> #define PETSC_HAVE_LIBPTSCOTCHERR 1
>> #define PETSC_HAVE_LIBEXOIIV2FOR 1
>> #define PETSC_HAVE_ERF 1
>> #define PETSC_HAVE_LIBSSL 1
>> #define PETSC_HAVE_LIBQUADMATH 1
>> #define PETSC_HAVE_LIBHDF5_FORTRAN 1
>> #define PETSC_HAVE_LIBCHACO 1
>> #define PETSC_HAVE_TGAMMA 1
>> #define PETSC_HAVE_LIBSCOTCH 1
>> #define PETSC_ARCH "linux-gnu-c-opt"
>> #define PETSC_CLANGUAGE_C 1
>> #define PETSC_USE_ERRORCHECKING 1
>> #define PETSC_MISSING_DREAL 1
>> #define PETSC_SIZEOF_MPI_COMM 8
>> #define PETSC_BITS_PER_BYTE 8
>> #define PETSC_SIZEOF_MPI_FINT 4
>> #define PETSC_SIZEOF_VOID_P 8
>> #define PETSC_RETSIGTYPE void
>> #define PETSC_HAVE_CXX_COMPLEX 1
>> #define PETSC_SIZEOF_LONG 8
>> #define PETSC_USE_FORTRANKIND 1
>> #define PETSC_SIZEOF_SIZE_T 8
>> #define PETSC_HAVE_SIGINFO_T 1
>> #define PETSC_SIZEOF_CHAR 1
>> #define PETSC_SIZEOF_DOUBLE 8
>> #define PETSC_SIZEOF_FLOAT 4
>> #define PETSC_HAVE_C99_COMPLEX 1
>> #define PETSC_SIZEOF_INT 4
>> #define PETSC_SIZEOF_LONG_LONG 8
>> #define PETSC_SIZEOF_SHORT 2
>> #define PETSC_HAVE_STRCASECMP 1
>> #define PETSC_HAVE_GET_NPROCS 1
>> #define PETSC_HAVE_POPEN 1
>> #define PETSC_HAVE_SIGSET 1
>> #define PETSC_HAVE_GETWD 1
>> #define PETSC_HAVE_VSNPRINTF 1
>> #define PETSC_HAVE_TIMES 1
>> #define PETSC_HAVE_DLSYM 1
>> #define PETSC_HAVE_SNPRINTF 1
>> #define PETSC_HAVE_GETHOSTBYNAME 1
>> #define PETSC_HAVE_GETCWD 1
>> #define PETSC_HAVE_DLERROR 1
>> #define PETSC_HAVE_FORK 1
>> #define PETSC_HAVE_RAND 1
>> #define PETSC_HAVE_GETTIMEOFDAY 1
>> #define PETSC_HAVE_DLCLOSE 1
>> #define PETSC_HAVE_UNAME 1
>> #define PETSC_HAVE_GETHOSTNAME 1
>> #define PETSC_HAVE_MKSTEMP 1
>> #define PETSC_HAVE_SIGACTION 1
>> #define PETSC_HAVE_DRAND48 1
>> #define PETSC_HAVE_MEMALIGN 1
>> #define PETSC_HAVE_VA_COPY 1
>> #define PETSC_HAVE_CLOCK 1
>> #define PETSC_HAVE_ACCESS 1
>> #define PETSC_HAVE_SIGNAL 1
>> #define PETSC_HAVE_USLEEP 1
>> #define PETSC_HAVE_GETRUSAGE 1
>> #define PETSC_HAVE_VFPRINTF 1
>> #define PETSC_HAVE_NANOSLEEP 1
>> #define PETSC_HAVE_GETDOMAINNAME 1
>> #define PETSC_HAVE_TIME 1
>> #define PETSC_HAVE_LSEEK 1
>> #define PETSC_HAVE_SOCKET 1
>> #define PETSC_HAVE_SYSINFO 1
>> #define PETSC_HAVE_READLINK 1
>> #define PETSC_HAVE_REALPATH 1
>> #define PETSC_HAVE_DLOPEN 1
>> #define PETSC_HAVE_MEMMOVE 1
>> #define PETSC_HAVE__GFORTRAN_IARGC 1
>> #define PETSC_HAVE_GETPAGESIZE 1
>> #define PETSC_HAVE_SLEEP 1
>> #define PETSC_HAVE_VPRINTF 1
>> #define PETSC_HAVE_BZERO 1
>> #define PETSC_SIGNAL_CAST
>> #define PETSC_WRITE_MEMORY_BARRIER() asm volatile("sfence":::"memory")
>> #define PETSC_MEMORY_BARRIER() asm volatile("mfence":::"memory")
>> #define PETSC_READ_MEMORY_BARRIER() asm volatile("lfence":::"memory")
>> #define PETSC_CPU_RELAX() asm volatile("rep; nop" ::: "memory")
>> #define HAVE_GZIP 1
>> #define PETSC_HAVE_MPI_COMM_C2F 1
>> #define PETSC_HAVE_MPI_COMBINER_CONTIGUOUS 1
>> #define PETSC_HAVE_MPI_EXSCAN 1
>> #define PETSC_HAVE_MPI_LONG_DOUBLE 1
>> #define PETSC_HAVE_MPI_COMM_F2C 1
>> #define PETSC_HAVE_MPI_FINT 1
>> #define PETSC_HAVE_MPI_F90MODULE 1
>> #define PETSC_HAVE_MPI_TYPE_GET_ENVELOPE 1
>> #define PETSC_HAVE_MPI_FINALIZED 1
>> #define PETSC_HAVE_MPI_COMM_SPAWN 1
>> #define PETSC_HAVE_MPI_TYPE_GET_EXTENT 1
>> #define PETSC_HAVE_MPI_COMBINER_DUP 1
>> #define PETSC_HAVE_MPI_WIN_CREATE 1
>> #define PETSC_HAVE_MPI_REPLACE 1
>> #define PETSC_HAVE_MPI_TYPE_DUP 1
>> #define PETSC_HAVE_MPIIO 1
>> #define PETSC_HAVE_MPI_INIT_THREAD 1
>> #define PETSC_HAVE_MPI_ALLTOALLW 1
>> #define PETSC_HAVE_MPI_IN_PLACE 1
>> #define PETSC_BLASLAPACK_UNDERSCORE 1
>> #define PETSC_HAVE_FORTRAN_GET_COMMAND_ARGUMENT 1
>> #define PETSC_HAVE_GFORTRAN_IARGC 1
>> #define PETSC_USE_FORTRAN_INTERFACES 1
>> #define PETSC_VERSION_DATE_GIT "2014-05-28 17:48:42 -0500"
>> #define PETSC_VERSION_GIT "v3.4.4-5825-g37198c6"
>> #define PETSC_USE_SCALAR_REAL 1
>> #define PETSC_HAVE_ISINF 1
>> #define PETSC_HAVE_ISNAN 1
>> #define PETSC_HAVE_ISNORMAL 1
>> #define PETSC_USE_REAL_DOUBLE 1
>> #define PETSC_USE_INFO 1
>> #define PETSC_Alignx(a,b)
>> #define PETSC_USE_BACKWARD_LOOP 1
>> #define PETSC_USE_DEBUG 1
>> #define PETSC_USE_LOG 1
>> #define PETSC_IS_COLOR_VALUE_TYPE short
>> #define PETSC_USE_CTABLE 1
>> #define PETSC__GNU_SOURCE 1
>> #define PETSC__BSD_SOURCE 1
>> #define PETSC_HAVE_DYNAMIC_LIBRARIES 1
>> #define PETSC_HAVE_SHARED_LIBRARIES 1
>> #define PETSC_USE_SHARED_LIBRARIES 1
>> #define PETSC_USE_GDB_DEBUGGER 1
>> #define PETSC_MEMALIGN 16
>> #define PETSC_LEVEL1_DCACHE_LINESIZE 64
>> #define PETSC_LEVEL1_DCACHE_SIZE 32768
>> #define PETSC_LEVEL1_DCACHE_ASSOC 8
>> #define PETSC_USE_PROC_FOR_SIZE 1
>> #define PETSC_HAVE_SCHED_CPU_SET_T 1
>> #define PETSC_HAVE_PTHREAD_BARRIER_T 1
>> #define PETSC_HAVE_SYS_SYSCTL_H 1
>> #define PETSC_HAVE_H5PSET_FAPL_MPIO 1
>> Using C/C++ compile: mpicc -c -fPIC -Wall -Wwrite-strings
>> -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 -I/home/acro018/software/PETSc/code/include
>> -I/home/acro018/software/PETSc/code/linux-gnu-c-opt/include
>> -I/usr/lib/include -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/
>> openmpi
>> mpicc -show: gcc -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi
>> -pthread -L/usr/lib/openmpi/lib -lmpi -lopen-rte -lopen-pal -ldl
>> -Wl,--export-dynamic -lnsl -lutil -lm -ldl
>> Using Fortran compile: mpif90 -c -fPIC -Wall -Wno-unused-variable
>> -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0
>> -I/home/acro018/software/PETSc/code/include -I/home/acro018/software/
>> PETSc/code/linux-gnu-c-opt/include -I/usr/lib/include
>> mpif90 -show: gfortran -I/usr/lib/openmpi/include -pthread
>> -I/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib -lmpi_f90 -lmpi_f77 -lmpi
>> -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl
>> Using C/C++ linker: mpicc
>> Using C/C++ flags: -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing
>> Using Fortran linker: mpif90
>> Using Fortran flags: -fPIC -Wall -Wno-unused-variable
>> Using libraries: -Wl,-rpath,/home/acro018/software/PETSc/code/linux-gnu-c-opt/lib
>> -L/home/acro018/software/PETSc/code/linux-gnu-c-opt/lib  -lpetsc
>> -llapack -lblas -Wl,-rpath,/home/acro018/software/PETSc/code/linux-gnu-c-opt/lib
>> -ltriangle -lX11 -lctetgen -lpthread -lchaco -lptesmumps -lptscotch
>> -lptscotcherr -lscotch -lscotcherr -lssl -lcrypto -lexoIIv2for -lexodus
>> -lnetcdf -Wl,-rpath,/usr/lib/lib -L/usr/lib/lib -lhdf5_fortran -lhdf5_hl
>> -lhdf5 -Wl,-rpath,/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib
>> -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.7 -L/usr/lib/gcc/x86_64-linux-gnu/4.7
>> -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu
>> -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lmpi_f90
>> -lmpi_f77 -lgfortran -lm -lgfortran -lm -lgfortran -lm -lquadmath -lm
>> -lmpi_cxx -lstdc++ -lrt -lm -lz -ldl -lmpi -lopen-rte -lopen-pal -lnsl
>> -lutil -lgcc_s -lpthread -ldl
>> Using mpiexec: mpiexec
>> Building PETSc using GNU Make with 7 build threads
>> make[2]: Entering directory `/home/acro018/software/PETSc/code'
>> /usr/bin/python conf/gmakegen.py --petsc-arch=linux-gnu-c-opt
>> make[2]: Leaving directory `/home/acro018/software/PETSc/code'
>> Use "/usr/bin/make V=1" to see the verbose compile lines.
>>           CC linux-gnu-c-opt/obj/src/sys/utils/arch.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/fhost.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/fuser.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/memc.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/mpiu.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/psleep.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/sortd.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/sorti.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/str.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/sortip.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/pbarrier.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/pdisplay.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/ctable.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/psplit.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/select.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/mpimesg.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/sseenabled.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/mpitr.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/mpilong.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/mathinf.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/mpits.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/segbuffer.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/mpitsf.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/sortipf.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/psplitf.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/mpiuf.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/sortdf.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/psleepf.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/sortif.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/memcf.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-custom/zarchf.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-custom/zstrf.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-custom/zpbarrierf.o
>>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-custom/zfhostf.o
>>           CC linux-gnu-c-opt/obj/src/sys/dll/dlimpl.o
>>           CC linux-gnu-c-opt/obj/src/sys/dll/dl.o
>>           CC linux-gnu-c-opt/obj/src/sys/dll/reg.o
>>           CC linux-gnu-c-opt/obj/src/sys/dll/ftn-auto/regf.o
>>           CC linux-gnu-c-opt/obj/src/sys/fileio/ffpath.o
>>           CC linux-gnu-c-opt/obj/src/sys/fileio/ftest.o
>>           CC linux-gnu-c-opt/obj/src/sys/fileio/ghome.o
>>           CC linux-gnu-c-opt/obj/src/sys/fileio/mpiuopen.o
>>           CC linux-gnu-c-opt/obj/src/sys/fileio/rpath.o
>>           CC linux-gnu-c-opt/obj/src/sys/fileio/fpath.o
>>           CC linux-gnu-c-opt/obj/src/sys/fileio/fwd.o
>>           CC linux-gnu-c-opt/obj/src/sys/fileio/grpath.o
>>           CC linux-gnu-c-opt/obj/src/sys/fileio/mprint.o
>>           CC linux-gnu-c-opt/obj/src/sys/fileio/sysio.o
>>           CC linux-gnu-c-opt/obj/src/sys/fileio/fretrieve.o
>>           CC linux-gnu-c-opt/obj/src/sys/fileio/smatlab.o
>>           CC linux-gnu-c-opt/obj/src/sys/fileio/ftn-auto/mpiuopenf.o
>>           CC linux-gnu-c-opt/obj/src/sys/fileio/ftn-auto/sysiof.o
>>           CC linux-gnu-c-opt/obj/src/sys/fileio/ftn-custom/zghomef.o
>>           CC linux-gnu-c-opt/obj/src/sys/fileio/ftn-custom/zmpiuopenf.o
>>           CC linux-gnu-c-opt/obj/src/sys/fileio/ftn-custom/zmprintf.o
>>           CC linux-gnu-c-opt/obj/src/sys/fileio/ftn-custom/zsysiof.o
>>           CC linux-gnu-c-opt/obj/src/sys/memory/mal.o
>>           CC linux-gnu-c-opt/obj/src/sys/memory/mem.o
>>           CC linux-gnu-c-opt/obj/src/sys/memory/mtr.o
>>           CC linux-gnu-c-opt/obj/src/sys/memory/ftn-auto/memf.o
>>           CC linux-gnu-c-opt/obj/src/sys/memory/ftn-custom/zmtrf.o
>>           CC linux-gnu-c-opt/obj/src/sys/threadcomm/impls/nothread/
>> nothread.o
>>           CC linux-gnu-c-opt/obj/src/sys/threadcomm/interface/
>> dlregisthreadcomm.o
>> threadcomm.o
>> threadcommregi.o
>> threadcommred.o
>>           CC linux-gnu-c-opt/obj/src/sys/threadcomm/interface/ftn-auto/
>> threadcommf.o
>>           CC linux-gnu-c-opt/obj/src/sys/ftn-custom/zsys.o
>>           CC linux-gnu-c-opt/obj/src/sys/ftn-custom/zutils.o
>>           CC linux-gnu-c-opt/obj/src/sys/python/pythonsys.o
>>           CC linux-gnu-c-opt/obj/src/sys/python/ftn-custom/zpythonf.o
>>           CC linux-gnu-c-opt/obj/src/sys/time/cputime.o
>>           CC linux-gnu-c-opt/obj/src/sys/time/fdate.o
>>           CC linux-gnu-c-opt/obj/src/sys/time/ftn-auto/cputimef.o
>>           CC linux-gnu-c-opt/obj/src/sys/time/ftn-custom/zptimef.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/version.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/gcomm.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/gtype.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/olist.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/pname.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/tagm.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/destroy.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/gcookie.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/inherit.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/options.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/pgname.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/prefix.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/init.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/pinit.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/ptype.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/state.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/aoptions.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/subcomm.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/fcallback.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/gcommf.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/destroyf.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/statef.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/tagmf.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/pinitf.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/ptypef.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/inheritf.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/optionsf.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zgcommf.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zoptionsf.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zpgnamef.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zpnamef.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zprefixf.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zdestroyf.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zstart.o
>>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zstartf.o
>>           CC linux-gnu-c-opt/obj/src/sys/totalview/tv_data_display.o
>>           CC linux-gnu-c-opt/obj/src/sys/info/verboseinfo.o
>>           CC linux-gnu-c-opt/obj/src/sys/info/ftn-auto/verboseinfof.o
>>           CC linux-gnu-c-opt/obj/src/sys/info/ftn-custom/zverboseinfof.o
>>           CC linux-gnu-c-opt/obj/src/sys/logging/plog.o
>>           CC linux-gnu-c-opt/obj/src/sys/logging/ftn-auto/plogf.o
>>           CC linux-gnu-c-opt/obj/src/sys/logging/utils/classlog.o
>>           CC linux-gnu-c-opt/obj/src/sys/logging/utils/stagelog.o
>>           CC linux-gnu-c-opt/obj/src/sys/logging/utils/eventlog.o
>>           CC linux-gnu-c-opt/obj/src/sys/logging/utils/stack.o
>>           CC linux-gnu-c-opt/obj/src/sys/logging/ftn-custom/zplogf.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/binary/
>> binv.o
>> ftn-auto/binvf.o
>> f90-custom/zbinvf90.o
>> ftn-custom/zbinvf.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/draw/
>> drawv.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/draw/ftn-
>> auto/drawvf.o
>> custom/zdrawvf.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/socket/
>> send.o
>> ftn-custom/zsendf.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/hdf5/
>> hdf5v.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/hdf5/ftn-
>> auto/hdf5vf.o
>> custom/zhdf5f.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/vtk/vtkv.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/vtk/ftn-
>> custom/zvtkvf.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/ascii/
>> filev.o
>> vcreatea.o
>> ftn-auto/filevf.o
>> ftn-custom/zfilevf.o
>> ftn-custom/zvcreatef.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/string/
>> stringv.o
>> ftn-custom/zstringvf.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/vu/
>> petscvu.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/view.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/flush.o
>> viewregall.o
>> viewreg.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/viewa.o
>> dlregispetsc.o
>> viewers.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/dupl.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/ftn-
>> auto/viewregf.o
>> auto/duplf.o
>> auto/viewf.o
>> auto/flushf.o
>> custom/zviewaf.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/bag/bag.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/bag/ftn-auto/bagf.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/bag/f90-custom/zbagf90.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/bag/ftn-custom/zbagf.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/xinit.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/wmap.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/xcolor.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/xops.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/text.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/tone.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/drawopenx.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/ftn-
>> custom/zdrawopenxf.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/tikz/tikz.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/draw.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dline.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dlinew.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dlinegw.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dtext.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dtextv.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dtexts.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dtextgs.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dpoint.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dpoints.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dviewp.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dcoor.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dpause.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dgpause.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dgcoor.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dbuff.o
>> dsetpause.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dflush.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dsflush.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dclear.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dsclear.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/drect.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dtri.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dmouse.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/drawreg.o
>> drawregall.o
>> dellipse.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-
>> auto/dlinegwf.o
>> auto/drectf.o
>> auto/dcoorf.o
>> auto/dtrif.o
>> auto/dlinewf.o
>> auto/drawregf.o
>> auto/dflushf.o
>> auto/dellipsef.o
>> auto/dtextsf.o
>> auto/dgpausef.o
>> auto/dsflushf.o
>> auto/dclearf.o
>> auto/dlinef.o
>> auto/dpointsf.o
>> auto/drawf.o
>> auto/dsetpausef.o
>> auto/dtextgsf.o
>> auto/dsclearf.o
>> auto/dmousef.o
>> auto/dbufff.o
>> auto/dpausef.o
>> auto/dviewpf.o
>> auto/dpointf.o
>> auto/dgcoorf.o
>> custom/zdrawf.o
>> custom/zdrawregf.o
>> custom/zdtextf.o
>> custom/zdtextvf.o
>> custom/zdtrif.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/axis.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/lg.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/dscatter.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/hists.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/zoom.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/hue.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/lgc.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/axisc.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/ftn-auto/
>> lgf.o
>> axiscf.o
>> dscatterf.o
>> axisf.o
>> lgcf.o
>> histsf.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/ftn-custom/
>> zaxisf.o
>> zzoomf.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/random/impls/rand/rand.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/random/impls/rand48/
>> rand48.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/random/interface/
>> random.o
>> randreg.o
>> dlregisrand.o
>> randomc.o
>>           CC linux-gnu-c-opt/obj/src/sys/classes/random/interface/ftn-
>> auto/randomcf.o
>> auto/randomf.o
>> custom/zrandomf.o
>>           CC linux-gnu-c-opt/obj/src/sys/error/adebug.o
>>           CC linux-gnu-c-opt/obj/src/sys/error/err.o
>>           CC linux-gnu-c-opt/obj/src/sys/error/errtrace.o
>>           CC linux-gnu-c-opt/obj/src/sys/error/errabort.o
>>           CC linux-gnu-c-opt/obj/src/sys/error/errstop.o
>>           CC linux-gnu-c-opt/obj/src/sys/error/fp.o
>>           CC linux-gnu-c-opt/obj/src/sys/error/signal.o
>>           CC linux-gnu-c-opt/obj/src/sys/error/pstack.o
>>           CC linux-gnu-c-opt/obj/src/sys/error/checkptr.o
>>           CC linux-gnu-c-opt/obj/src/sys/error/ftn-auto/fpf.o
>>           CC linux-gnu-c-opt/obj/src/sys/error/ftn-auto/adebugf.o
>>           CC linux-gnu-c-opt/obj/src/sys/error/ftn-auto/checkptrf.o
>>           CC linux-gnu-c-opt/obj/src/sys/error/ftn-auto/errf.o
>>           CC linux-gnu-c-opt/obj/src/sys/error/ftn-auto/signalf.o
>>           CC linux-gnu-c-opt/obj/src/sys/error/ftn-custom/zerrf.o
>>           CC linux-gnu-c-opt/obj/src/sys/webclient/client.o
>>           CC linux-gnu-c-opt/obj/src/sys/webclient/google.o
>>           CC linux-gnu-c-opt/obj/src/sys/webclient/box.o
>>           CC linux-gnu-c-opt/obj/src/sys/webclient/textbelt.o
>>           CC linux-gnu-c-opt/obj/src/sys/webclient/globus.o
>>           CC linux-gnu-c-opt/obj/src/sys/f90-src/f90_cwrap.o
>>           FC linux-gnu-c-opt/obj/src/sys/objects/f2003-src/fsrc/
>> optionenum.o
>>           FC linux-gnu-c-opt/obj/src/sys/classes/bag/f2003-src/fsrc/
>> bagenum.o
>>           FC linux-gnu-c-opt/obj/src/sys/fsrc/somefort.o
>>           FC linux-gnu-c-opt/obj/src/sys/f90-mod/petscsysmod.o
>>           FC linux-gnu-c-opt/obj/src/sys/f90-src/fsrc/f90_fwrap.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/is/impls/f90-custom/
>> zblockf90.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/is/impls/stride/stride.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/is/impls/stride/ftn-auto/
>> stridef.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/is/impls/block/block.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/is/impls/block/ftn-auto/
>> blockf.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/is/impls/block/ftn-custom/
>> zblockf.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/is/impls/general/general.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/is/impls/general/ftn-auto/
>> generalf.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/is/interface/index.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/is/interface/isregall.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/is/interface/isreg.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/is/interface/ftn-auto/
>> isregf.o
>> indexf.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/is/interface/f90-custom/
>> zindexf90.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/is/interface/ftn-custom/
>> zindexf.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/iscomp.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/iscoloring.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/isdiff.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/isblock.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/ftn-auto/iscompf.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/ftn-auto/isdifff.o
>> iscoloringf.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/f90-custom/
>> ziscoloringf90.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/ftn-custom/
>> ziscoloringf.o
>> zisltogf.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/utils/isio.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/utils/isltog.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/utils/pmap.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/utils/vsectionis.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/utils/ftn-auto/vsectionisf.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/utils/ftn-auto/isltogf.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/sf/impls/window/sfwindow.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/sf/impls/basic/sfbasic.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/sf/interface/dlregissf.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/sf/interface/sfregi.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/sf/interface/sf.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/sf/interface/sftype.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/sf/interface/ftn-auto/sff.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/ao/impls/memscalable/
>> aomemscalable.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/ao/impls/mapping/aomapping.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/ao/impls/mapping/ftn-auto/
>> aomappingf.o
>> custom/zaomappingf.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/ao/impls/basic/aobasic.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/ao/impls/basic/ftn-custom/
>> zaobasicf.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/ao/interface/ao.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/ao/interface/dlregisdm.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/ao/interface/aoreg.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/ao/interface/aoregall.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/ao/interface/ftn-auto/aof.o
>>           CC linux-gnu-c-opt/obj/src/vec/is/ao/interface/ftn-custom/
>> zaof.o
>>           CC linux-gnu-c-opt/obj/src/vec/pf/impls/constant/const.o
>>           CC linux-gnu-c-opt/obj/src/vec/pf/impls/string/cstring.o
>>           CC linux-gnu-c-opt/obj/src/vec/pf/interface/pf.o
>>           CC linux-gnu-c-opt/obj/src/vec/pf/interface/pfall.o
>>           CC linux-gnu-c-opt/obj/src/vec/pf/interface/ftn-auto/pff.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/shared/shvec.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/shared/ftn-auto/
>> shvecf.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/nest/vecnest.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/nest/ftn-auto/
>> vecnestf.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/nest/ftn-custom/
>> zvecnestf.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/seq/bvec2.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/seq/bvec1.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/seq/dvec2.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/seq/vseqcr.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/seq/bvec3.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/seq/ftn-auto/vseqcrf.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/seq/ftn-custom/
>> zbvec2f.o
>> zvsectionf.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/pbvec.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/pdvec.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/pvec2.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/vmpicr.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/commonmpvec.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/ftn-auto/
>> commonmpvecf.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/ftn-auto/pbvecf.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/ftn-auto/vmpicrf.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/ftn-custom/
>> zpbvecf.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/interface/vector.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/interface/veccreate.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/interface/vecreg.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/interface/vecregall.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/interface/dlregisvec.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/interface/rvector.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/interface/ftn-auto/
>> veccreatef.o
>> rvectorf.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/interface/ftn-auto/vectorf.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/interface/f90-custom/
>> zvectorf90.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/interface/ftn-custom/
>> zvecregf.o
>> zvectorf.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vinv.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vscat.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vpscat.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/cmesh.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vecio.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/comb.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vecstash.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vecmpitoseq.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vecs.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vsection.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/projection.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-auto/vinvf.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-auto/cmeshf.o
>> vecmpitoseqf.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-auto/projectionf.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-auto/vpscatf.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-auto/combf.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-auto/veciof.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-auto/vscatf.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/f90-custom/
>> zvsectionf90.o
>>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-custom/zvscatf.o
>>           FC linux-gnu-c-opt/obj/src/vec/f90-mod/petscvecmod.o
>>           CC linux-gnu-c-opt/obj/src/mat/coarsen/coarsen.o
>>           CC linux-gnu-c-opt/obj/src/mat/coarsen/scoarsen.o
>>           CC linux-gnu-c-opt/obj/src/mat/coarsen/impls/hem/hem.o
>>           CC linux-gnu-c-opt/obj/src/mat/coarsen/impls/mis/mis.o
>>           CC linux-gnu-c-opt/obj/src/mat/coarsen/ftn-auto/coarsenf.o
>>           CC linux-gnu-c-opt/obj/src/mat/ftn-custom/zmat.o
>>           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/color.o
>>           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/degr.o
>>           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/dsm.o
>>           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/ido.o
>>           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/numsrt.o
>>           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/seq.o
>>           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/setr.o
>>           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/slo.o
>>           CC linux-gnu-c-opt/obj/src/mat/color/impls/natural/natural.o
>>           CC linux-gnu-c-opt/obj/src/mat/color/impls/jp/jp.o
>>           CC linux-gnu-c-opt/obj/src/mat/color/impls/greedy/greedy.o
>>           CC linux-gnu-c-opt/obj/src/mat/color/impls/power/power.o
>>           CC linux-gnu-c-opt/obj/src/mat/color/interface/matcoloring.o
>> matcoloringregi.o
>>           CC linux-gnu-c-opt/obj/src/mat/color/interface/ftn-auto/
>> matcoloringf.o
>>           CC linux-gnu-c-opt/obj/src/mat/color/interface/ftn-custom/
>> zmatcoloringf.o
>>           CC linux-gnu-c-opt/obj/src/mat/color/utils/bipartite.o
>>           CC linux-gnu-c-opt/obj/src/mat/color/utils/valid.o
>>           CC linux-gnu-c-opt/obj/src/mat/color/utils/weights.o
>>           CC linux-gnu-c-opt/obj/src/mat/utils/convert.o
>>           CC linux-gnu-c-opt/obj/src/mat/utils/matstash.o
>>           CC linux-gnu-c-opt/obj/src/mat/utils/axpy.o
>>           CC linux-gnu-c-opt/obj/src/mat/utils/zerodiag.o
>>           CC linux-gnu-c-opt/obj/src/mat/utils/getcolv.o
>>           CC linux-gnu-c-opt/obj/src/mat/utils/gcreate.o
>>           CC linux-gnu-c-opt/obj/src/mat/utils/freespace.o
>>           CC linux-gnu-c-opt/obj/src/mat/utils/compressedrow.o
>>           CC linux-gnu-c-opt/obj/src/mat/utils/multequal.o
>>           CC linux-gnu-c-opt/obj/src/mat/utils/matstashspace.o
>>           CC linux-gnu-c-opt/obj/src/mat/utils/pheap.o
>>           CC linux-gnu-c-opt/obj/src/mat/utils/bandwidth.o
>>           CC linux-gnu-c-opt/obj/src/mat/utils/ftn-auto/gcreatef.o
>>           CC linux-gnu-c-opt/obj/src/mat/utils/ftn-auto/multequalf.o
>>           CC linux-gnu-c-opt/obj/src/mat/utils/ftn-auto/zerodiagf.o
>>           CC linux-gnu-c-opt/obj/src/mat/utils/ftn-auto/bandwidthf.o
>>           CC linux-gnu-c-opt/obj/src/mat/utils/ftn-auto/axpyf.o
>>           CC linux-gnu-c-opt/obj/src/mat/utils/ftn-auto/getcolvf.o
>>           CC linux-gnu-c-opt/obj/src/mat/partition/partition.o
>>           CC linux-gnu-c-opt/obj/src/mat/partition/impls/scotch/scotch.o
>>           CC linux-gnu-c-opt/obj/src/mat/partition/spartition.o
>>           CC linux-gnu-c-opt/obj/src/mat/partition/impls/scotch/ftn-
>> auto/scotchf.o
>>           CC linux-gnu-c-opt/obj/src/mat/partition/impls/chaco/chaco.o
>>           CC linux-gnu-c-opt/obj/src/mat/partition/impls/chaco/ftn-
>> auto/chacof.o
>>           CC linux-gnu-c-opt/obj/src/mat/partition/ftn-auto/partitionf.o
>>           CC linux-gnu-c-opt/obj/src/mat/partition/ftn-custom/
>> zpartitionf.o
>>           CC linux-gnu-c-opt/obj/src/mat/interface/matrix.o
>>           CC linux-gnu-c-opt/obj/src/mat/interface/mhas.o
>>           CC linux-gnu-c-opt/obj/src/mat/interface/matreg.o
>>           CC linux-gnu-c-opt/obj/src/mat/interface/matregis.o
>>           CC linux-gnu-c-opt/obj/src/mat/interface/matnull.o
>>           CC linux-gnu-c-opt/obj/src/mat/interface/dlregismat.o
>>           CC linux-gnu-c-opt/obj/src/mat/interface/ftn-auto/matrixf.o
>>           CC linux-gnu-c-opt/obj/src/mat/interface/ftn-auto/mhasf.o
>>           CC linux-gnu-c-opt/obj/src/mat/interface/ftn-auto/matnullf.o
>>           CC linux-gnu-c-opt/obj/src/mat/interface/f90-custom/
>> zmatrixf90.o
>>           CC linux-gnu-c-opt/obj/src/mat/interface/ftn-custom/zmatregf.o
>>           CC linux-gnu-c-opt/obj/src/mat/interface/ftn-custom/zmatrixf.o
>>           CC linux-gnu-c-opt/obj/src/mat/interface/ftn-custom/zmatnullf.o
>>           CC linux-gnu-c-opt/obj/src/mat/matfd/fdmatrix.o
>>           CC linux-gnu-c-opt/obj/src/mat/matfd/ftn-auto/fdmatrixf.o
>>           CC linux-gnu-c-opt/obj/src/mat/matfd/ftn-custom/zfdmatrixf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/submat/submat.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/submat/ftn-auto/submatf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/is/matis.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/is/ftn-auto/matisf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/fft/fft.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/fft/ftn-auto/fftf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baij.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baij2.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact2.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgefa.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgedi.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgefa3.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgefa4.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgefa5.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgefa2.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgefa6.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgefa7.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/aijbaij.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact3.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact4.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact5.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact7.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact9.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact11.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact13.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijsolvtrannat.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijsolvtran.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijsolv.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijsolvnat.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/ftn-auto/baijf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/ftn-custom/
>> zbaijf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/bstream/bstream.o
>> bstrmfact.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/mpi/mpibaij.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/mpi/mmbaij.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/mpi/baijov.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/mpi/mpb_baij.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/mpi/ftn-auto/
>> mpibaijf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/mpi/ftn-custom/
>> zmpibaijf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/mpi/bstream/
>> mpibstream.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/localref/mlocalref.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/localref/ftn-auto/
>> mlocalreff.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/mffd.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/mffddef.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/mfregis.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/wp.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/ftn-auto/mffddeff.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/ftn-auto/mffdf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/ftn-auto/wpf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/ftn-custom/zmffdf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/composite/mcomposite.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/composite/ftn-auto/
>> mcompositef.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/adj/mpi/mpiadj.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/adj/mpi/ftn-auto/mpiadjf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/adj/mpi/ftn-custom/
>> zmpiadjf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/maij/maij.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/lrc/lrc.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/lrc/ftn-auto/lrcf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/shell/shell.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/shell/shellcnv.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/shell/ftn-auto/shellf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/shell/ftn-custom/zshellf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/normal/normm.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/normal/ftn-auto/normmf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/python/pythonmat.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/python/ftn-custom/
>> zpythonmf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/nest/matnest.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/nest/ftn-auto/matnestf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/nest/ftn-custom/
>> zmatnestf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/transpose/transm.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/transpose/ftn-auto/
>> transmf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/dense/seq/dense.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/dense/seq/ftn-custom/
>> zdensef.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/dense/mpi/mpidense.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/dense/mpi/mmdense.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/dense/mpi/ftn-auto/
>> mpidensef.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/dense/mpi/ftn-custom/
>> zmpidensef.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/blockmat/seq/blockmat.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaij.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaij2.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact2.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sro.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact3.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact4.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact5.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact6.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact7.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact8.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact9.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact10.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact11.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact12.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/aijsbaij.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbstream/
>> sbstream.o
>> sbstrmfact.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/ftn-auto/
>> sbaijf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/ftn-custom/
>> zsbaijf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/mpi/mpisbaij.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/mpi/mmsbaij.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/mpi/sbaijov.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/mpi/mpiaijsbaij.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/mpi/ftn-auto/
>> mpisbaijf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/mpi/ftn-custom/
>> zmpisbaijf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/mpi/sbstream/
>> mpisbstream.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/aij.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/aijfact.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/ij.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/fdaij.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/matmatmult.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/symtranspose.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/matptap.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/matrart.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/inode.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/inode2.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/matmatmatmult.o
>> mattransposematmult.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/ftn-custom/zaijf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/bas/basfactor.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/bas/spbas.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/csrperm/csrperm.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/ftn-auto/aijf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/crl/crl.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpiaij.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mmaij.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpiaijpc.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpiov.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/fdmpiaij.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpiptap.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpimatmatmult.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpb_aij.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpimatmatmatmult.o
>> mpimattransposematmult.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/ftn-custom/
>> zmpiaijf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/csrperm/
>> mpicsrperm.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/ftn-auto/mpiaijf.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/crl/mcrl.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/scatter/mscatter.o
>>           CC linux-gnu-c-opt/obj/src/mat/impls/scatter/ftn-auto/
>> mscatterf.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/sp1wd.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/spnd.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/spqmd.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/sprcm.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/sorder.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/spectral.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/sregis.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/degree.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/fnroot.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/genqmd.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/qmdqt.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/rcm.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/fn1wd.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/gen1wd.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/genrcm.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/qmdrch.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/rootls.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/fndsep.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/gennd.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/qmdmrg.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/qmdupd.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/wbm.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/ftn-auto/spectralf.o
>>           CC linux-gnu-c-opt/obj/src/mat/order/ftn-custom/zsorderf.o
>>           FC linux-gnu-c-opt/obj/src/mat/f90-mod/petscmatmod.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/shell/dmshell.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/shell/ftn-auto/dmshellf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/shell/ftn-custom/
>> zdmshellf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/composite/pack.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/composite/packm.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/composite/ftn-auto/packf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/composite/f90-custom/
>> zfddaf90.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/composite/ftn-custom/
>> zfddaf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/da2.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/da1.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/da3.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/daghost.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dacorn.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dagtol.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/daltol.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/daindex.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dascatter.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dacreate.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dadestroy.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dalocal.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dadist.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/daview.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dasub.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/gr1.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/gr2.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dagtona.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dainterp.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dapf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dagetarray.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dagetelem.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/da.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dareg.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/fdda.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/grvtk.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dageometry.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dadd.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dapreallocate.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/gr1f.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/fddaf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dagtolf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dadistf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dacreatef.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dalocalf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dagtonaf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/daindexf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/daghostf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/daf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dacornf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dainterpf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dageometryf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/daddf.o
>> dapreallocatef.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dagetarrayf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zdaf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zda1f.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zda2f.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zda3f.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zdacornf.o
>> zdagetscatterf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zdaindexf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zdaviewf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/f90-custom/zdaindexf90.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/da/f90-custom/zda1f90.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/redundant/dmredundant.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/redundant/ftn-auto/
>> dmredundantf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexcreate.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plex.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexpartition.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexdistribute.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexrefine.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexinterpolate.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexpreallocate.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexreorder.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexgeometry.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexlabel.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexsubmesh.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexhdf5.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexexodusii.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexgmsh.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexcgns.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexvtk.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexpoint.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexvtu.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexfem.o
>> /home/acro018/software/PETSc/code/src/dm/impls/plex/plexfem.c: In
>> function ‘DMPlexProjectFieldLocal’:
>> /home/acro018/software/PETSc/code/src/dm/impls/plex/plexfem.c:359:51:
>> warning: variable ‘numCells’ set but not used [-Wunused-but-set-variable]
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexindices.o
>> /home/acro018/software/PETSc/code/src/dm/impls/plex/plexfem.c:416:33:
>> warning: ‘x’ may be used uninitialized in this function [-Wuninitialized]
>> /home/acro018/software/PETSc/code/src/dm/impls/plex/plexfem.c:417:37:
>> warning: ‘cOffset’ may be used uninitialized in this function
>> [-Wuninitialized]
>> warning: ‘coefficients’ may be used uninitialized in this function
>> [-Wuninitialized]
>> /home/acro018/software/PETSc/code/src/dm/impls/plex/plexfem.c:417:18:
>> warning: ‘u’ may be used uninitialized in this function [-Wuninitialized]
>> warning: ‘gradU’ may be used uninitialized in this function
>> [-Wuninitialized]
>> /home/acro018/software/PETSc/code/src/dm/impls/plex/plexfem.c:418:37:
>> warning: ‘cOffsetAux’ may be used uninitialized in this function
>> [-Wuninitialized]
>> warning: ‘coefficientsAux’ may be used uninitialized in this function
>> [-Wuninitialized]
>> /home/acro018/software/PETSc/code/src/dm/impls/plex/plexfem.c:418:18:
>> warning: ‘a’ may be used uninitialized in this function [-Wuninitialized]
>> warning: ‘gradA’ may be used uninitialized in this function
>> [-Wuninitialized]
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexlabelf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexgmshf.o
>> plexexodusiif.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexcreatef.o
>> plexindicesf.o
>> plexinterpolatef.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexpointf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexfemf.o
>> plexsubmeshf.o
>> plexdistributef.o
>> plexreorderf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexcgnsf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexrefinef.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexf.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/f90-custom/zplexf90.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-custom/zplex.o
>> zplexinterpolate.o
>> zplexsubmesh.o
>> zplexlabel.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/sliced/sliced.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/circuit/circuitcreate.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/circuit/circuit.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/circuit/ftn-auto/circuitf.o
>> circuitcreatef.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/patch/patchcreate.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/patch/patch.o
>>           CC linux-gnu-c-opt/obj/src/dm/impls/patch/ftn-auto/
>> patchcreatef.o
>>           CC linux-gnu-c-opt/obj/src/dm/interface/dm.o
>>           CC linux-gnu-c-opt/obj/src/dm/interface/dmregall.o
>>           CC linux-gnu-c-opt/obj/src/dm/interface/dmget.o
>>           CC linux-gnu-c-opt/obj/src/dm/interface/dmi.o
>>           CC linux-gnu-c-opt/obj/src/dm/interface/dlregisdmdm.o
>>           CC linux-gnu-c-opt/obj/src/dm/interface/ftn-auto/dmf.o
>>           CC linux-gnu-c-opt/obj/src/dm/interface/ftn-auto/dmgetf.o
>>           CC linux-gnu-c-opt/obj/src/dm/interface/ftn-custom/zdmf.o
>>           CC linux-gnu-c-opt/obj/src/dm/interface/ftn-custom/zdmgetf.o
>>           CC linux-gnu-c-opt/obj/src/dm/dt/interface/dt.o
>>           CC linux-gnu-c-opt/obj/src/dm/dt/interface/dtfe.o
>>           CC linux-gnu-c-opt/obj/src/dm/dt/interface/dtfv.o
>>           CC linux-gnu-c-opt/obj/src/dm/dt/interface/dtproblem.o
>>           CC linux-gnu-c-opt/obj/src/dm/dt/interface/ftn-auto/dtfef.o
>>           CC linux-gnu-c-opt/obj/src/dm/dt/interface/ftn-auto/dtfvf.o
>>           CC linux-gnu-c-opt/obj/src/dm/dt/interface/ftn-auto/dtf.o
>>           CC linux-gnu-c-opt/obj/src/dm/dt/interface/ftn-auto/dtproblemf.
>> o
>>           FC linux-gnu-c-opt/obj/src/dm/f90-mod/petscdmmod.o
>>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/lsc/lsc.o
>>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/eisens/eisen.o
>> /home/acro018/software/PETSc/code/src/dm/dt/interface/dtfe.c: In
>> function ‘PetscFEIntegrate_Basic’:
>> /home/acro018/software/PETSc/code/src/dm/dt/interface/dtfe.c:2881:15:
>> warning: ‘obj_func’ may be used uninitialized in this function
>> [-Wuninitialized]
>> function ‘PetscFEIntegrateBdResidual_Nonaffine’:
>> /home/acro018/software/PETSc/code/src/dm/dt/interface/dtfe.c:3522:14:
>> warning: ‘refSpaceDer’ may be used uninitialized in this function
>> [-Wuninitialized]
>> function ‘PetscFEIntegrateResidual_Nonaffine’:
>> /home/acro018/software/PETSc/code/src/dm/dt/interface/dtfe.c:3464:14:
>> [-Wuninitialized]
>>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/eisens/ftn-auto/
>> eisenf.o
>>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/is/pcis.o
>>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/is/ftn-auto/pcisf.o
>>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/is/nn/nn.o
>>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/mg.o
>>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/fmg.o
>>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/smg.o
>>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/mgfunc.o
>> /home/acro018/software/PETSc/code/include/finclude/ftn-
>> auto/petscdm.h90:112.7:
>>     Included at /home/acro018/software/PETSc/
>> code/include/finclude/petscdm.h90:9:
>>     Included at /home/acro018/software/PETSc/code/src/dm/f90-mod/
>> petscdmmod.F:25:
>>        PetscProblem prob ! PetscProblem
>>        1
>> Error: Unclassifiable statement at (1)
>> auto/petscdm.h90:116.7:
>> petscdmmod.F:25:
>>        1
>> auto/petscdm.h90:121.7:
>> petscdmmod.F:25:
>>        1
>>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/ftn-auto/mgf.o
>>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/ftn-auto/mgfuncf.o
>>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/ftn-custom/zmgf.o
>> /home/acro018/software/PETSc/code/src/dm/f90-mod/petscdmmod.F:35.11:
>>         use petscdm
>>            1
>> Fatal Error: Can't open module file 'petscdm.mod' for reading at (1): No
>> such file or directory
>> make[2]: *** [linux-gnu-c-opt/obj/src/dm/f90-mod/petscdmmod.o] Error 1
>> make[2]: *** Waiting for unfinished jobs....
>> make[1]: *** [gnumake] Error 2
>> make[1]: Leaving directory `/home/acro018/software/PETSc/code'
>> [1;31m**************************ERROR***********************
>>   Error during compile, check linux-gnu-c-opt/conf/make.log
>>   Send it and linux-gnu-c-opt/conf/configure.log to
>> petsc-maint at mcs.anl.gov
>> [0;39m [0;49m
>> Finishing at: Thu May 29 11:29:48 NZST 2014
>> Dr Adrian Croucher
>> Senior Research Fellow
>> Department of Engineering Science
>> University of Auckland, New Zealand
>> email: a.croucher at auckland.ac.nz
>> tel: +64 (0)9 923 4611
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140528/c6bfebb0/attachment.html>
