[petsc-dev] TS ex11 crashing in parallel
Adrian Croucher a.croucher at auckland.ac.nz
Tue May 27 23:19:10 CDT 2014
hi
The TS ex11 example (from 'next' branch) runs OK for me in serial, but
crashes when I run it in parallel (for any number of processors > 1).
Output from serial and parallel runs is below. Any clues as to what has
gone wrong?
Cheers, Adrian
1) Serial:
acro018 at des108:~/software/PETSc/code/src/ts/examples/tutorials$ mpirun
-np 1 ex11 -f ${PETSC_DIR}/share/petsc/datafiles/meshes/sevensi
de-quad.exo -advect_sol_type BUMP
   0  time        0  |x|   0.2425
   1  time   0.3311  |x|   0.1401
   2  time   0.6623  |x|  0.07485
   3  time   0.9934  |x|   0.0455
   4  time    1.325  |x|   0.0316
   5  time    1.656  |x|  0.02646
   6  time    1.987  |x|  0.02069
   7  time    2.318  |x|  0.01547
CONVERGED_TIME at time 2.31791 after 7 steps
2) Same thing in parallel:
-np 2 ex11 -f ${PETSC_DIR}/share/petsc/datafiles/meshes/sevensi
   0  time        0  |x|   0.2425
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Argument out of range
[0]PETSC ERROR: Point 0 has 0 constraints > -2 dof
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.4.4-5803-gabde81b
GIT Date: 2014-05-26 14:52:58 -0500
[0]PETSC ERROR: ex11 on a linux-gnu-c-opt named des108 by acro018 Wed
May 28 16:14:26 2014
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Argument out of range
[1]PETSC ERROR: Point 3 has 0 constraints > -2 dof
[1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
[1]PETSC ERROR: Petsc Development GIT revision: v3.4.4-5803-gabde81b
[1]PETSC ERROR: ex11 on a linux-gnu-c-opt named des108 by acro018 Wed
[1]PETSC ERROR: Configure options --download-netcdf --download-exodusii
--with-hdf5-dir=/usr/lib --with-numpy-dir=/usr/lib/pymodules/p
ython2.7/numpy
--with-scientificpython-dir=/usr/lib/python2.7/dist-packages/scipy
--with-petsc4py-dir=/usr/local/lib/python2.7/dist-pa
ckages/petsc4py --download-triangle --with-fortran-interfaces=1
--download-ptscotch --download-chaco --download-ctetgen
[1]PETSC ERROR: #1 DMCreateDefaultSF() line 3066 in
/home/acro018/software/PETSc/code/src/dm/interface/dm.c
[1]PETSC ERROR: #2 DMGetDefaultSF() line 2986 in
[1]PETSC ERROR: #3 DMGlobalToLocalBegin() line 1646 in
[1]PETSC ERROR: #4 VecView_Plex() line 118 in
/home/acro018/software/PETSc/code/src/dm/impls/plex/plex.c
[1]PETSC ERROR: #5 VecView() line 601 in
/home/acro018/software/PETSc/code/src/vec/vec/interface/vector.c
[1]PETSC ERROR: #6 MonitorVTK() line 1395 in
/home/acro018/software/PETSc/code/src/ts/examples/tutorials/ex11.c
[1]PETSC ERROR: [0]PETSC ERROR: Configure options --download-netcdf
--download-exodusii --with-hdf5-dir=/usr/lib --with-numpy-dir=/usr
/lib/pymodules/python2.7/numpy
ython2.7/dist-packages/petsc4py --download-triangle
--with-fortran-interfaces=1 --download-ptscotch --download-chaco
--download-ctetge
n
[0]PETSC ERROR: #1 DMCreateDefaultSF() line 3066 in
[0]PETSC ERROR: #2 DMGetDefaultSF() line 2986 in
[0]PETSC ERROR: #7 TSMonitor() line 2810 in
/home/acro018/software/PETSc/code/src/ts/interface/ts.c
[1]PETSC ERROR: #8 TSSolve() line 2752 in
[1]PETSC ERROR: #9 main() line 1541 in
[1]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
[0]PETSC ERROR: #4 VecView_Plex() line 118 in
[0]PETSC ERROR: #5 VecView() line 601 in
[0]PETSC ERROR: #6 MonitorVTK() line 1395 in
[0]PETSC ERROR: #8 TSSolve() line 2752 in
[0]PETSC ERROR: #9 main() line 1541 in
[0]PETSC ERROR: ----------------End of Error Message -------send entire
MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
with errorcode 63.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
mpirun has exited due to process rank 1 with PID 606 on
node des108 exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
[des108:00604] 1 more process has sent help message help-mpi-api.txt /
mpi-abort
[des108:00604] Set MCA parameter "orte_base_help_aggregate" to 0 to see
all help / error messages
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
