[petsc-dev] problem with petscdm.h90
Adrian Croucher a.croucher at auckland.ac.nz
Mon May 19 18:42:14 CDT 2014
On 20/05/14 02:42, Matthew Knepley wrote:
> All this stuff has now been fixed in master, and I added a test of
> ex11 for shallow water that uses
> reconstruction and limiters.
Thanks Matt. I'm still getting one warning when I compile TS ex11 (using
gcc 4.7.2), on either master or next branch- it doesn't seem to be
entirely happy with the type of the function passed into
DMPlexTSSetRHSFunctionLocal():
/home/acro018/software/PETSc/code/src/ts/examples/tutorials/ex11.c: In
function ‘main’:
/home/acro018/software/PETSc/code/src/ts/examples/tutorials/ex11.c:1515:3:
warning: passing argument 2 of ‘DMPlexTSSetRHSFunctionLocal
’ from incompatible pointer type [enabled by default]
In file included from
/home/acro018/software/PETSc/code/src/ts/examples/tutorials/ex11.c:37:0:
/home/acro018/software/PETSc/code/include/petscts.h:342:29: note:
expected ‘void (*)(const PetscReal *, const PetscReal *, const Petsc
Scalar *, const PetscScalar *, PetscScalar *, void *)’ but argument is
of type ‘RiemannFunction’
Cheers, Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140520/5fdbff77/attachment.html>
