[petsc-dev] TAO data files
Jed Brown jed at jedbrown.org
Fri May 16 22:45:31 CDT 2014
Satish Balay <balay at mcs.anl.gov> writes:
> for one - I didn't look closely at all files in tao. [I assumed
> 'src/docs/tex' on tao was similar to stuff on petsc side - and moved
> it over to src/docs/tao_tex]
> And secondly - I was preserving the tao repo history [in separate
> branches].  So - unless I was purging stuff from tao history - this
> would be in the repo anyway.. [even if it was removed before merge]
Right, it would have had to be stripped before the merge.  It's too late
to fix now without forcing everyone to reclone, but it's an awfully
large amount of space that is useless to almost everyone.  Those figures
can surely be created at a tenth the size without compromising quality.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140516/f26147d3/attachment.sig>
