[petsc-dev] TAO data files
Fri May 16 22:45:26 CDT 2014
  We had move the PETSc tutorial presentations out of PETSc a number of years ago because of this issue. I guess this never happened for tao.
   I think that stuff should be moved to a tao tutorials repository and purged from the PETSc repository.
   Barry
On May 16, 2014, at 10:42 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> for one - I didn't look closely at all files in tao. [I assumed
> 'src/docs/tex' on tao was similar to stuff on petsc side - and moved
> it over to src/docs/tao_tex]
> And secondly - I was preserving the tao repo history [in separate
> branches].  So - unless I was purging stuff from tao history - this
> would be in the repo anyway.. [even if it was removed before merge]
> Satish
> On Fri, 16 May 2014, Jed Brown wrote:
>> Why did we merge this?
>> -rwxr-xr-x 1 jed users 14M Apr  9 20:06 src/docs/tao_tex/tutorials/images/interpmodel.eps
>> There's actually a number of multi-MB eps files that have found their
>> way into the repository.
>>  $ du -hs src/docs/*tex
>>  37M     src/docs/tao_tex
>>  3.8M    src/docs/tex
>> This data is transferred every time someone clones the repository.
