[petsc-dev] making DA more light weight
Jed Brown jed at jedbrown.org
Thu May 15 20:00:22 CDT 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
>   Damn it Jed, I already told you the sequential case does NOT have the optimization for bs > 1. Run in the debugger on two processes and put a break point in ISGetIndices() and you will see that it is not used by the VecScatterCreate() inside the DMDACreate …
>> $ mpirun.hydra -n 2 ./ex20 -malloc_log -malloc_log_threshold 1e6
>> If you run as above in a debugger with a break point at ISGetIndices,
>> the first break is at
>> $ mpirun.hydra -n 1 gdb -ex 'b ISGetIndices' -ex r --args ./ex20 : -n 1  ./ex20
>   You are not running as above since you went from 2 to 1 process where completely different code is used in creating the scatter!
Barry, this really is a two-process job, despite the fact that I'm only
attaching a debugger to rank 0.  Same with the debugger traces below.
It's standard mpiexec syntax.
   mpiexec args executable pgmargs [ : args executable pgmargs ... ]
>> [0] 3 12713984 DMSetUp_DA_3D()
>> [0] 1 4259840 ISBlockSetIndices_Block()
>> [0] 4 169738240 ISGetIndices_Block()
>             This number above is NOT in the VecScatterCreate() it is in the creation of the local to global mapping
>> [0] 1 41943040 ISGetIndices_Stride()
>> [0] 1 4259840 ISLocalToGlobalMappingBlock()
>> [0] 2 167772160 VecCreate_MPI_Private()
>> [0] 10 339476480 VecScatterCreate_PtoS()
>                ^^^^ I admit this number is larger than I would like to see but it is not caused by ISGetIndices
>    Barry
> Likely we can just remove the sequential case from the checks in the VecScatter and always do the “parallel” and thus remove the unoptimized code that you keep tripping over.
>>>> Note that ISGetIndices is still called in the parallel case.
>>>   When bs is set > 1 it is not called in the VecScatterCreate()
>>>   inside the DMDACreate 2d/3d ! Only ISBlockGetIndices() is
>>>   called. The memory usage of VecScatterCreate() is O(dof*number of
>>>   ghost points) + O(vector length/dof) in this case
>>>  It is called MULTIPLY times in the ISLocalToGlobalMappingCreateIS()
>>>  inside the DMDACreate 2d/3d thus currently this causes small integer
>>>  * vector length usage. As I keep telling you this is the problem
>>>  area for dof > 1.  For dof == 1 I can live with 2.5 *sizeof (vector)
>>>   You need a better test code to run with. Can you use
>>>   ksp/ksp/examples/tests/ex42.c ? Or snes/examples/tutorials/ex19.c
>>>   in parallel?
>> I added a simple test for this purpose, src/dm/examples/tests/ex20.c
>> in 'jed/dmda-memusage'.
>> DMDACreate3d        :  225.866 MB +  225.866 MB
>> DMCreateGlobalVector:  309.666 MB +   83.800 MB
>> DMCreateGlobalVector:  393.552 MB +   83.886 MB
>> [0] Maximum memory PetscMalloc()ed 386401520 maximum size of entire process 309821440
>> [0] Memory usage sorted by function
>> GNU gdb (GDB) 7.7.1
>> Copyright (C) 2014 Free Software Foundation, Inc.
>> License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
>> This is free software: you are free to change and redistribute it.
>> There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
>> and "show warranty" for details.
>> This GDB was configured as "x86_64-unknown-linux-gnu".
>> Type "show configuration" for configuration details.
>> For bug reporting instructions, please see:
>> <http://www.gnu.org/software/gdb/bugs/>.
>> Find the GDB manual and other documentation resources online at:
>> <http://www.gnu.org/software/gdb/documentation/>.
>> For help, type "help".
>> Type "apropos word" to search for commands related to "word"...
>> No symbol table is loaded.  Use the "file" command.
>> Breakpoint 1 (err.c:343) pending.
>> Reading symbols from ./ex20...done.
>> Function "ISGetIndices" not defined.
>> Breakpoint 2 (ISGetIndices) pending.
>> Starting program: /home/jed/petsc/src/dm/examples/tests/ex20
>> warning: Could not load shared library symbols for linux-vdso.so.1.
>> Do you need "set solib-search-path" or "set sysroot"?
>> [Thread debugging using libthread_db enabled]
>> Using host libthread_db library "/usr/lib/libthread_db.so.1".
>> Breakpoint 2, ISGetIndices (is=0x506840, ptr=0x7fffffffd328) at /home/jed/petsc/src/vec/is/is/interface/index.c:379
>> 379       PetscFunctionBegin;
>> (gdb) bt
>> #0  ISGetIndices (is=0x506840, ptr=0x7fffffffd328) at /home/jed/petsc/src/vec/is/is/interface/index.c:379
>> #1  0x00007ffff6a60cb9 in VecScatterCreate (xin=0x4fbfb0, ix=0x506840, yin=0x4f8d10, iy=0x503210, newctx=0x7fffffffd888) at /home/jed/petsc/src/vec/vec/utils/vscat.c:1579
>> #2  0x00007ffff7129d9b in DMSetUp_DA_3D (da=0x4e3280) at /home/jed/petsc/src/dm/impls/da/da3.c:448
>> #3  0x00007ffff71a3ef5 in DMSetUp_DA (da=0x4e3280) at /home/jed/petsc/src/dm/impls/da/dareg.c:27
>> #4  0x00007ffff736fd9f in DMSetUp (dm=0x4e3280) at /home/jed/petsc/src/dm/interface/dm.c:559
>> #5  0x00007ffff71330b1 in DMDACreate3d (comm=1140850688, bx=DM_BOUNDARY_NONE, by=DM_BOUNDARY_NONE, bz=DM_BOUNDARY_NONE, stencil_type=DMDA_STENCIL_STAR, M=-128, N=-128, P=-128, m=-1, n=-1, p=-1, dof=10, s=1, lx=0x0, ly=0x0, lz=0x0, da=0x7fffffffdd58) at /home/jed/petsc/src/dm/impls/da/da3.c:1463
>> #6  0x0000000000400c96 in main (argc=1, argv=0x7fffffffde58) at /home/jed/petsc/src/dm/examples/tests/ex20.c:15
>> That is this code, which dates from 1995 according to git annotate.
>>    /* general case */
>>      PetscInt       nx,ny;
>>      const PetscInt *idx,*idy;
>>      ierr = ISGetLocalSize(ix,&nx);CHKERRQ(ierr);
>>      ierr = ISGetIndices(ix,&idx);CHKERRQ(ierr);
>>      ierr = ISGetLocalSize(iy,&ny);CHKERRQ(ierr);
>>      ierr = ISGetIndices(iy,&idy);CHKERRQ(ierr);
>>      if (nx != ny) SETERRQ(PETSC_COMM_SELF,PETSC_ERR_ARG_SIZ,"Local scatter sizes don't match");
>>      ierr = VecScatterCreate_StoP(nx,idx,ny,idy,xin,yin,1,ctx);CHKERRQ(ierr);
>>      ierr = ISRestoreIndices(ix,&idx);CHKERRQ(ierr);
>>      ierr = ISRestoreIndices(iy,&idy);CHKERRQ(ierr);
>>      ierr = PetscInfo(xin,"General case: Seq to MPI\n");CHKERRQ(ierr);
>>      goto functionend;
>> Here are all the large allocations, found by stepping through printing
>> the stack trace for each case.
>> $ mpirun.hydra -n 1 gdb -ex 'b mtr.c:228' -ex r --args ./ex20 -malloc_log -malloc_log_threshold 1e7 : -n 1  ./ex20
>> (gdb) bt
>> #0  PetscTrMallocDefault (a=41943040, lineno=47, function=0x7ffff7afd5d4 <.L__func__.ISGetIndices_Block> "ISGetIndices_Block", filename=0x7ffff7afd53b <.L.str> "/home/jed/petsc/src/vec/is/is/impls/block/block.c", result=0x7fffffffcf88) at /home/jed/petsc/src/sys/memory/mtr.c:228
>> #1  0x00007ffff691fad2 in ISGetIndices_Block (in=0x4cbe90, idx=0x7fffffffd2f8) at /home/jed/petsc/src/vec/is/is/impls/block/block.c:47
>> #2  0x00007ffff6936468 in ISGetIndices (is=0x4cbe90, ptr=0x7fffffffd2f8) at /home/jed/petsc/src/vec/is/is/interface/index.c:382
>> #3  0x00007ffff6a60cb9 in VecScatterCreate (xin=0x4c1600, ix=0x4cbe90, yin=0x4be360, iy=0x4c8860, newctx=0x7fffffffd858) at /home/jed/petsc/src/vec/vec/utils/vscat.c:1579
>> #4  0x00007ffff7129d9b in DMSetUp_DA_3D (da=0x4a88d0) at /home/jed/petsc/src/dm/impls/da/da3.c:448
>> #5  0x00007ffff71a3ef5 in DMSetUp_DA (da=0x4a88d0) at /home/jed/petsc/src/dm/impls/da/dareg.c:27
>> #6  0x00007ffff736fd9f in DMSetUp (dm=0x4a88d0) at /home/jed/petsc/src/dm/interface/dm.c:559
>> #7  0x00007ffff71330b1 in DMDACreate3d (comm=1140850688, bx=DM_BOUNDARY_NONE, by=DM_BOUNDARY_NONE, bz=DM_BOUNDARY_NONE, stencil_type=DMDA_STENCIL_STAR, M=-128, N=-128, P=-128, m=-1, n=-1, p=-1, dof=10, s=1, lx=0x0, ly=0x0, lz=0x0, da=0x7fffffffdd28) at /home/jed/petsc/src/dm/impls/da/da3.c:1463
>> #8  0x0000000000400c96 in main (argc=4, argv=0x7fffffffde28) at /home/jed/petsc/src/dm/examples/tests/ex20.c:15
>> #0  PetscTrMallocDefault (a=41943040, lineno=160, function=0x7ffff7afd32b <.L__func__.ISGetIndices_Stride> "ISGetIndices_Stride", filename=0x7ffff7afd279 <.L.str> "/home/jed/petsc/src/vec/is/is/impls/stride/stride.c", result=0x7fffffffd2f0) at /home/jed/petsc/src/sys/memory/mtr.c:228
>> #1  0x00007ffff691b1e9 in ISGetIndices_Stride (in=0x4c8860, idx=0x7fffffffd2f0) at /home/jed/petsc/src/vec/is/is/impls/stride/stride.c:160
>> #2  0x00007ffff6936468 in ISGetIndices (is=0x4c8860, ptr=0x7fffffffd2f0) at /home/jed/petsc/src/vec/is/is/interface/index.c:382
>> #3  0x00007ffff6a60da7 in VecScatterCreate (xin=0x4c1600, ix=0x4cbe90, yin=0x4be360, iy=0x4c8860, newctx=0x7fffffffd858) at /home/jed/petsc/src/vec/vec/utils/vscat.c:1581
>> #0  PetscTrMallocDefault (a=41943040, lineno=1745, function=0x7ffff7b0449a <.L__func__.VecScatterCreate_PtoS> "VecScatterCreate_PtoS", filename=0x7ffff7b03f29 <.L.str> "/home/jed/petsc/src/vec/vec/utils/vpscat.c", result=0x7fffffffcee0) at /home/jed/petsc/src/sys/memory/mtr.c:228
>> #1  0x00007ffff6a9129f in VecScatterCreate_PtoS (nx=10485760, inidx=0x7fffe9086650, ny=10485760, inidy=0x7fffeb887650, xin=0x4be360, yin=0x4c1600, bs=1, ctx=0x4d2ea0) at /home/jed/petsc/src/vec/vec/utils/vpscat.c:1745
>> #2  0x00007ffff6a94c2d in VecScatterCreate_StoP (nx=10485760, inidx=0x7fffeb887650, ny=10485760, inidy=0x7fffe9086650, xin=0x4c1600, yin=0x4be360, bs=1, ctx=0x4d2ea0) at /home/jed/petsc/src/vec/vec/utils/vpscat.c:2197
>> #3  0x00007ffff6a60ea0 in VecScatterCreate (xin=0x4c1600, ix=0x4cbe90, yin=0x4be360, iy=0x4c8860, newctx=0x7fffffffd858) at /home/jed/petsc/src/vec/vec/utils/vscat.c:1583
>> #0  PetscTrMallocDefault (a=41943040, lineno=1784, function=0x7ffff7b0449a <.L__func__.VecScatterCreate_PtoS> "VecScatterCreate_PtoS", filename=0x7ffff7b03f29 <.L.str> "/home/jed/petsc/src/vec/vec/utils/vpscat.c", result=0x7fffffffcec0) at /home/jed/petsc/src/sys/memory/mtr.c:228
>> #1  0x00007ffff6a91c5f in VecScatterCreate_PtoS (nx=10485760, inidx=0x7fffe9086650, ny=10485760, inidy=0x7fffeb887650, xin=0x4be360, yin=0x4c1600, bs=1, ctx=0x4d2ea0) at /home/jed/petsc/src/vec/vec/utils/vpscat.c:1784
>> #0  PetscTrMallocDefault (a=41943040, lineno=1879, function=0x7ffff7b0449a <.L__func__.VecScatterCreate_PtoS> "VecScatterCreate_PtoS", filename=0x7ffff7b03f29 <.L.str> "/home/jed/petsc/src/vec/vec/utils/vpscat.c", result=0x50fae0) at /home/jed/petsc/src/sys/memory/mtr.c:228
>> #1  0x00007ffff6a9423b in VecScatterCreate_PtoS (nx=10485760, inidx=0x7fffe9086650, ny=10485760, inidy=0x7fffeb887650, xin=0x4be360, yin=0x4c1600, bs=1, ctx=0x4d2ea0) at /home/jed/petsc/src/vec/vec/utils/vpscat.c:1879
>> #0  PetscTrMallocDefault (a=41943040, lineno=1880, function=0x7ffff7b0449a <.L__func__.VecScatterCreate_PtoS> "VecScatterCreate_PtoS", filename=0x7ffff7b03f29 <.L.str> "/home/jed/petsc/src/vec/vec/utils/vpscat.c", result=0x510860) at /home/jed/petsc/src/sys/memory/mtr.c:228
>> #1  0x00007ffff6a9431f in VecScatterCreate_PtoS (nx=10485760, inidx=0x7fffe9086650, ny=10485760, inidy=0x7fffeb887650, xin=0x4be360, yin=0x4c1600, bs=1, ctx=0x4d2ea0) at /home/jed/petsc/src/vec/vec/utils/vpscat.c:1880
>> #0  PetscTrMallocDefault (a=42598400, lineno=47, function=0x7ffff7afd5d4 <.L__func__.ISGetIndices_Block> "ISGetIndices_Block", filename=0x7ffff7afd53b <.L.str> "/home/jed/petsc/src/vec/is/is/impls/block/block.c", result=0x7fffffffcf88) at /home/jed/petsc/src/sys/memory/mtr.c:228
>> #1  0x00007ffff691fad2 in ISGetIndices_Block (in=0x4cf6a0, idx=0x7fffffffd370) at /home/jed/petsc/src/vec/is/is/impls/block/block.c:47
>> #2  0x00007ffff6936468 in ISGetIndices (is=0x4cf6a0, ptr=0x7fffffffd370) at /home/jed/petsc/src/vec/is/is/interface/index.c:382
>> #3  0x00007ffff6a5f84a in VecScatterCreate (xin=0x4be360, ix=0x4cf6a0, yin=0x4c1600, iy=0x50ede0, newctx=0x7fffffffd850) at /home/jed/petsc/src/vec/vec/utils/vscat.c:1493
>> #4  0x00007ffff712ed23 in DMSetUp_DA_3D (da=0x4a88d0) at /home/jed/petsc/src/dm/impls/da/da3.c:1033
>> #1  0x00007ffff691fad2 in ISGetIndices_Block (in=0x50ede0, idx=0x7fffffffd368) at /home/jed/petsc/src/vec/is/is/impls/block/block.c:47
>> #2  0x00007ffff6936468 in ISGetIndices (is=0x50ede0, ptr=0x7fffffffd368) at /home/jed/petsc/src/vec/is/is/interface/index.c:382
>> #3  0x00007ffff6a5f938 in VecScatterCreate (xin=0x4be360, ix=0x4cf6a0, yin=0x4c1600, iy=0x50ede0, newctx=0x7fffffffd850) at /home/jed/petsc/src/vec/vec/utils/vscat.c:1495
>> #0  PetscTrMallocDefault (a=42598400, lineno=1745, function=0x7ffff7b0449a <.L__func__.VecScatterCreate_PtoS> "VecScatterCreate_PtoS", filename=0x7ffff7b03f29 <.L.str> "/home/jed/petsc/src/vec/vec/utils/vpscat.c", result=0x7fffffffcf80) at /home/jed/petsc/src/sys/memory/mtr.c:228
>> #1  0x00007ffff6a9129f in VecScatterCreate_PtoS (nx=10649600, inidx=0x7fffeafb5650, ny=10649600, inidy=0x7fffe17e3650, xin=0x4be360, yin=0x4c1600, bs=1, ctx=0x514f70) at /home/jed/petsc/src/vec/vec/utils/vpscat.c:1745
>> #2  0x00007ffff6a5fa49 in VecScatterCreate (xin=0x4be360, ix=0x4cf6a0, yin=0x4c1600, iy=0x50ede0, newctx=0x7fffffffd850) at /home/jed/petsc/src/vec/vec/utils/vscat.c:1497
>> #3  0x00007ffff712ed23 in DMSetUp_DA_3D (da=0x4a88d0) at /home/jed/petsc/src/dm/impls/da/da3.c:1033
>> #4  0x00007ffff71a3ef5 in DMSetUp_DA (da=0x4a88d0) at /home/jed/petsc/src/dm/impls/da/dareg.c:27
>> #5  0x00007ffff736fd9f in DMSetUp (dm=0x4a88d0) at /home/jed/petsc/src/dm/interface/dm.c:559
>> #6  0x00007ffff71330b1 in DMDACreate3d (comm=1140850688, bx=DM_BOUNDARY_NONE, by=DM_BOUNDARY_NONE, bz=DM_BOUNDARY_NONE, stencil_type=DMDA_STENCIL_STAR, M=-128, N=-128, P=-128, m=-1, n=-1, p=-1, dof=10, s=1, lx=0x0, ly=0x0, lz=0x0, da=0x7fffffffdd28) at /home/jed/petsc/src/dm/impls/da/da3.c:1463
>> #7  0x0000000000400c96 in main (argc=4, argv=0x7fffffffde28) at /home/jed/petsc/src/dm/examples/tests/ex20.c:15
>> #0  PetscTrMallocDefault (a=42598400, lineno=1784, function=0x7ffff7b0449a <.L__func__.VecScatterCreate_PtoS> "VecScatterCreate_PtoS", filename=0x7ffff7b03f29 <.L.str> "/home/jed/petsc/src/vec/vec/utils/vpscat.c", result=0x7fffffffcf60) at /home/jed/petsc/src/sys/memory/mtr.c:228
>> #1  0x00007ffff6a91c5f in VecScatterCreate_PtoS (nx=10649600, inidx=0x7fffeafb5650, ny=10649600, inidy=0x7fffe17e3650, xin=0x4be360, yin=0x4c1600, bs=1, ctx=0x514f70) at /home/jed/petsc/src/vec/vec/utils/vpscat.c:1784
>> #0  PetscTrMallocDefault (a=41943040, lineno=1879, function=0x7ffff7b0449a <.L__func__.VecScatterCreate_PtoS> "VecScatterCreate_PtoS", filename=0x7ffff7b03f29 <.L.str> "/home/jed/petsc/src/vec/vec/utils/vpscat.c", result=0x5b9850) at /home/jed/petsc/src/sys/memory/mtr.c:228
>> #1  0x00007ffff6a9423b in VecScatterCreate_PtoS (nx=10649600, inidx=0x7fffeafb5650, ny=10649600, inidy=0x7fffe17e3650, xin=0x4be360, yin=0x4c1600, bs=1, ctx=0x514f70) at /home/jed/petsc/src/vec/vec/utils/vpscat.c:1879
>> #0  PetscTrMallocDefault (a=41943040, lineno=1880, function=0x7ffff7b0449a <.L__func__.VecScatterCreate_PtoS> "VecScatterCreate_PtoS", filename=0x7ffff7b03f29 <.L.str> "/home/jed/petsc/src/vec/vec/utils/vpscat.c", result=0x516ba0) at /home/jed/petsc/src/sys/memory/mtr.c:228
>> #1  0x00007ffff6a9431f in VecScatterCreate_PtoS (nx=10649600, inidx=0x7fffeafb5650, ny=10649600, inidy=0x7fffe17e3650, xin=0x4be360, yin=0x4c1600, bs=1, ctx=0x514f70) at /home/jed/petsc/src/vec/vec/utils/vpscat.c:1880
>> #0  PetscTrMallocDefault (a=42598400, lineno=47, function=0x7ffff7afd5d4 <.L__func__.ISGetIndices_Block> "ISGetIndices_Block", filename=0x7ffff7afd53b <.L.str> "/home/jed/petsc/src/vec/is/is/impls/block/block.c", result=0x7fffffffd4b8) at /home/jed/petsc/src/sys/memory/mtr.c:228
>> #1  0x00007ffff691fad2 in ISGetIndices_Block (in=0x50ede0, idx=0x7fffffffd5e0) at /home/jed/petsc/src/vec/is/is/impls/block/block.c:47
>> #2  0x00007ffff6936468 in ISGetIndices (is=0x50ede0, ptr=0x7fffffffd5e0) at /home/jed/petsc/src/vec/is/is/interface/index.c:382
>> #3  0x00007ffff68eb66a in ISLocalToGlobalMappingCreateIS (is=0x50ede0, mapping=0x4a97a0) at /home/jed/petsc/src/vec/is/utils/isltog.c:139
>> #4  0x00007ffff713216f in DMSetUp_DA_3D (da=0x4a88d0) at /home/jed/petsc/src/dm/impls/da/da3.c:1362
>> #0  PetscTrMallocDefault (a=83886080, lineno=197, function=0x7ffff7b0171f <.L__func__.VecCreate_MPI_Private> "VecCreate_MPI_Private", filename=0x7ffff7b01735 <.L.str> "/home/jed/petsc/src/vec/vec/impls/mpi/pbvec.c", result=0x513b60) at /home/jed/petsc/src/sys/memory/mtr.c:228
>> #1  0x00007ffff69e33d8 in VecCreate_MPI_Private (v=0x511c30, alloc=PETSC_TRUE, nghost=0, array=0x0) at /home/jed/petsc/src/vec/vec/impls/mpi/pbvec.c:197
>> #2  0x00007ffff69e3f5b in VecCreate_MPI (vv=0x511c30) at /home/jed/petsc/src/vec/vec/impls/mpi/pbvec.c:240
>> #3  0x00007ffff6a17cd1 in VecSetType (vec=0x511c30, method=0x7ffff7b01763 <.L.str6> "mpi") at /home/jed/petsc/src/vec/vec/interface/vecreg.c:53
>> #4  0x00007ffff69e4395 in VecCreate_Standard (v=0x511c30) at /home/jed/petsc/src/vec/vec/impls/mpi/pbvec.c:267
>> #5  0x00007ffff6a17cd1 in VecSetType (vec=0x511c30, method=0x4b9b00 "standard") at /home/jed/petsc/src/vec/vec/interface/vecreg.c:53
>> #6  0x00007ffff715ad11 in DMCreateGlobalVector_DA (da=0x4a88d0, g=0x7fffffffdd20) at /home/jed/petsc/src/dm/impls/da/dadist.c:43
>> #7  0x00007ffff7370f54 in DMCreateGlobalVector (dm=0x4a88d0, vec=0x7fffffffdd20) at /home/jed/petsc/src/dm/interface/dm.c:680
>> #8  0x0000000000400e25 in main (argc=4, argv=0x7fffffffde28) at /home/jed/petsc/src/dm/examples/tests/ex20.c:20
>> #0  PetscTrMallocDefault (a=83886080, lineno=197, function=0x7ffff7b0171f <.L__func__.VecCreate_MPI_Private> "VecCreate_MPI_Private", filename=0x7ffff7b01735 <.L.str> "/home/jed/petsc/src/vec/vec/impls/mpi/pbvec.c", result=0x4c9550) at /home/jed/petsc/src/sys/memory/mtr.c:228
>> #1  0x00007ffff69e33d8 in VecCreate_MPI_Private (v=0x4d0ad0, alloc=PETSC_TRUE, nghost=0, array=0x0) at /home/jed/petsc/src/vec/vec/impls/mpi/pbvec.c:197
>> #2  0x00007ffff69e3f5b in VecCreate_MPI (vv=0x4d0ad0) at /home/jed/petsc/src/vec/vec/impls/mpi/pbvec.c:240
>> #3  0x00007ffff6a17cd1 in VecSetType (vec=0x4d0ad0, method=0x7ffff7b01763 <.L.str6> "mpi") at /home/jed/petsc/src/vec/vec/interface/vecreg.c:53
>> #4  0x00007ffff69e4395 in VecCreate_Standard (v=0x4d0ad0) at /home/jed/petsc/src/vec/vec/impls/mpi/pbvec.c:267
>> #5  0x00007ffff6a17cd1 in VecSetType (vec=0x4d0ad0, method=0x4b9b00 "standard") at /home/jed/petsc/src/vec/vec/interface/vecreg.c:53
>> #6  0x00007ffff715ad11 in DMCreateGlobalVector_DA (da=0x4a88d0, g=0x7fffffffdd18) at /home/jed/petsc/src/dm/impls/da/dadist.c:43
>> #7  0x00007ffff7370f54 in DMCreateGlobalVector (dm=0x4a88d0, vec=0x7fffffffdd18) at /home/jed/petsc/src/dm/interface/dm.c:680
>> #8  0x0000000000400fb6 in main (argc=4, argv=0x7fffffffde28) at /home/jed/petsc/src/dm/examples/tests/ex20.c:25
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140515/cc0c6f51/attachment.sig>
