[petsc-dev] making DA more light weight
Jed Brown jed at jedbrown.org
Thu May 15 14:27:58 CDT 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
>    Hmm, this is the sequential case where no optimization was done for
>    block indices (adding additional code to handle the blocks would
>    not be that difficult). In the parallel case if the indices are
>    block then ISGetIndices() is not suppose to ever be used (is it?)
>    instead only ISBlockGetIndices() is used.
>    Can this plot be produced for the parallel case?
$ PETSC_ARCH=mpich-opt mpirun.hydra -n 1 python2 -m memory_profiler ketch-dmda.py 128 3 1 : -n 1 python2 ketch-dmda.py 128 3 1
Filename: ketch-dmda.py
Line #    Mem usage    Increment   Line Contents
    11   23.336 MiB    0.000 MiB   @profile
    12                             def foo(size=128,ndim=3,dof=1):
    13   51.688 MiB   28.352 MiB       da = PETSc.DA().create(sizes=[size]*ndim,dof=dof)
    14   59.711 MiB    8.023 MiB       q1 = da.createGlobalVec()
    15   67.715 MiB    8.004 MiB       q2 = da.createGlobalVec()
    16   75.719 MiB    8.004 MiB       q3 = da.createGlobalVec()
$ PETSC_ARCH=mpich-opt mpirun.hydra -n 1 python2 -m memory_profiler ketch-dmda.py 128 3 10 : -n 1 python2 ketch-dmda.py 128 3 10
    13  235.711 MiB  212.375 MiB       da = PETSc.DA().create(sizes=[size]*ndim,dof=dof)
    14  315.734 MiB   80.023 MiB       q1 = da.createGlobalVec()
    15  395.738 MiB   80.004 MiB       q2 = da.createGlobalVec()
    16  475.742 MiB   80.004 MiB       q3 = da.createGlobalVec()
So creating the DMDA still costs 2.5x as much as a Vec.  See here for
the massif-visualizer plot:
  http://59A2.org/files/dmda-memory-p2.png
  $ PETSC_ARCH=mpich-opt mpirun.hydra -n 1 valgrind --tool=massif python2 ketch-dmda.py 128 3 10 : -n 1 python2 ketch-dmda.py 128 3 10
  ==3243== Massif, a heap profiler
  ==3243== Copyright (C) 2003-2013, and GNU GPL'd, by Nicholas Nethercote
  ==3243== Using Valgrind-3.9.0 and LibVEX; rerun with -h for copyright info
  ==3243== Command: python2 ketch-dmda.py 128 3 10
  ==3243==
  ==3243==
Note that ISGetIndices is still called in the parallel case.
Type: text/x-python
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140515/afa996ee/attachment.py>
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140515/afa996ee/attachment.sig>
