[petsc-dev] configuring PETSC for a cluster with GPUs
Karl Rupp rupp at iue.tuwien.ac.at
Tue May 13 10:32:12 CDT 2014
 > I'm trying to configure PETSc in an cluster with multiple GPUs, one per
> node.
> I read it is possible to use PETSc with N processes, one per GPU, each
> process accesses to its own GPU. Isn't it?
yes, this is possible and the recommended way of running it.
> Can anyone help me in that configuration?
> should I change the code to realize communication and exchange between
> processes on different GPUs?
No, this is all handled internally by PETSc. If your code handles
'standard PETSc with MPI on the CPU', then the use of GPUs is just a
matter of providing the right flags (-vec_type XXX -mat_type YYY).
Which algorithms do you intend to run? Many solver-related algorithms
don't map well to massively parallel architectures such as GPUs, so you
may better want to run a more efficient CPU-based algorithm.
Best regards,
Karli
