[petsc-dev] [petsc-users] Override PETSc compile options
Jed Brown jed at jedbrown.org
Fri May 9 16:18:37 CDT 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
>   So why not just rename the strange PETSc variables by using the
>   standard names prepended with PETSC_ this will be much clearer and
>   is a simple etags refactorization of the code that should take just
>   a few minutes (and since “no body uses these variables”) won’t even
>   be noticed by anyone.
It's slightly less trivial, but I agree and will do this (maintaining
backward compatibility for a while).
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140509/34831a28/attachment.sig>
