[petsc-dev] [petsc-users] Override PETSc compile options
Jed Brown jed at jedbrown.org
Thu May 8 09:14:56 CDT 2014
Satish Balay <balay at mcs.anl.gov> writes:
> On Wed, 7 May 2014, TAY wee-beng wrote:
>> Hi Matt,
>> Sorry, I mean during the compilation of my own codes using my own makefile.
> $ grep Wall arch-linux2-c-debug/conf/petscvariables
> FC_LINKER_FLAGS =    -fPIC -Wall -Wno-unused-variable -Wno-unused-dummy-argument -g -O0
> CC_FLAGS =  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0
> FC_FLAGS =  -fPIC -Wall -Wno-unused-variable -Wno-unused-dummy-argument -g -O0
> CXX_FLAGS =  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0   -fPIC
> PCC_LINKER_FLAGS =    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0
> PCC_FLAGS =  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0
> balay at asterix /home/balay/petsc (master)
Why does PETSc specify these redundantly using non-standard names as
opposed to CFLAGS, CPPFLAGS, LDFLAGS, etc?  I never remember which name
is used where so I have to grep conf/variables and petscvariables every
time.  (I'd rather those be namespaced, but that's another issue.)
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140508/c6a72681/attachment.sig>
