[petsc-dev] sizeof(PetscInt) from buildsystem
Jed Brown jed at jedbrown.org
Tue May 6 10:22:31 CDT 2014
Matthew Knepley <knepley at gmail.com> writes:
>> > 1) The python2 requirement is easily changed
>> Not so easily without compromising python2.4 compatibility.
>> > 2) You could compress it all into one line. I wanted to show what was
>> > happening.
>> Still complicated (many interfaces).
> 2
2 would be
import petsc.conf
print(petsc.conf('64-bit-indices'))
> I pray in 5 years our interface is not UNIX piping and grepping. We
> have finally eliminated most of the horrible shell that was in our
> makefiles. I hope we do not go backwards.
Then make something better.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140506/de5a2220/attachment.sig>
