[petsc-dev] sizeof(PetscInt) from buildsystem
Jed Brown jed at jedbrown.org
Tue May 6 10:13:13 CDT 2014
Matthew Knepley <knepley at gmail.com> writes:
> 1) The python2 requirement is easily changed
Not so easily without compromising python2.4 compatibility.
> 2) You could compress it all into one line. I wanted to show what was
> happening.
Still complicated (many interfaces).
> 3) It much more flexible, namespaced, and does not involve output files
> which may change.
We can look back in 5 years and see which one works unmodified.  I
suspect that petscconf.h is more stable than all those Python
interfaces.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140506/83f7f811/attachment.sig>
