[petsc-dev] [PATCH] DMPlex: refine coordinates using spatial dimension
Lawrence Mitchell lawrence.mitchell at imperial.ac.uk
Mon May 5 09:35:30 CDT 2014
If the plex is an embedded manifold, its topological dimension will not
match the dimension of the coordinate section.  Refine coordinates by
inspecting the latter (rather than the former) when carrying out uniform
refinement.
 I sent this a while ago, but I'm not sure if it got lost in transit
 (hence reposting to petsc-dev for comment).  It's possible that
 something similar needs to be done for non-uniform refinement, but
 I'm not sure how to drive those interfaces.  We need this, for
 example, when refining a mesh of the surface of the earth.
Cheers,
Lawrence
 src/dm/impls/plex/plexrefine.c | 32 ++++++++++++++++----------------
 1 file changed, 16 insertions(+), 16 deletions(-)
diff --git a/src/dm/impls/plex/plexrefine.c b/src/dm/impls/plex/plexrefine.c
index fe4d71d..d6cbc74 100644
--- a/src/dm/impls/plex/plexrefine.c
+++ b/src/dm/impls/plex/plexrefine.c
@@ -5339,11 +5339,10 @@ static PetscErrorCode CellRefinerSetCoordinates(CellRefiner refiner, DM dm, Pets
   Vec            coordinates, coordinatesNew;
   PetscScalar   *coords, *coordsNew;
   const PetscInt numVertices = depthSize ? depthSize[0] : 0;
-  PetscInt       dim, depth, bs, coordSizeNew, cStart, cEnd, cMax, c, vStart, vStartNew, vEnd, v, eStart, eEnd, eMax, e, fStart, fEnd, fMax, f;
+  PetscInt       spaceDim, depth, bs, coordSizeNew, cStart, cEnd, cMax, c, vStart, vStartNew, vEnd, v, eStart, eEnd, eMax, e, fStart, fEnd, fMax, f;
   PetscErrorCode ierr;
   PetscFunctionBegin;
-  ierr = DMPlexGetDimension(dm, &dim);CHKERRQ(ierr);
   ierr = DMPlexGetDepth(dm, &depth);CHKERRQ(ierr);
   ierr = DMPlexGetDepthStratum(dm, 0, &vStart, &vEnd);CHKERRQ(ierr);
   ierr = DMPlexGetDepthStratum(dm, 1, &eStart, &eEnd);CHKERRQ(ierr);
@@ -5353,17 +5352,18 @@ static PetscErrorCode CellRefinerSetCoordinates(CellRefiner refiner, DM dm, Pets
   if (refiner) {ierr = GetDepthStart_Private(depth, depthSize, NULL, NULL, NULL, &vStartNew);CHKERRQ(ierr);}
   ierr = DMGetCoordinateSection(dm, &coordSection);CHKERRQ(ierr);
+  ierr = PetscSectionGetFieldComponents(coordSection, 0, &spaceDim);CHKERRQ(ierr);
   ierr = PetscSectionCreate(PetscObjectComm((PetscObject)dm), &coordSectionNew);CHKERRQ(ierr);
   ierr = PetscSectionSetNumFields(coordSectionNew, 1);CHKERRQ(ierr);
-  ierr = PetscSectionSetFieldComponents(coordSectionNew, 0, dim);CHKERRQ(ierr);
+  ierr = PetscSectionSetFieldComponents(coordSectionNew, 0, spaceDim);CHKERRQ(ierr);
   ierr = PetscSectionSetChart(coordSectionNew, vStartNew, vStartNew+numVertices);CHKERRQ(ierr);
   if (cMax < 0) cMax = cEnd;
   if (fMax < 0) fMax = fEnd;
   if (eMax < 0) eMax = eEnd;
-  /* All vertices have the dim coordinates */
+  /* All vertices have spaceDim coordinates */
   for (v = vStartNew; v < vStartNew+numVertices; ++v) {
-    ierr = PetscSectionSetDof(coordSectionNew, v, dim);CHKERRQ(ierr);
-    ierr = PetscSectionSetFieldDof(coordSectionNew, v, 0, dim);CHKERRQ(ierr);
+    ierr = PetscSectionSetDof(coordSectionNew, v, spaceDim);CHKERRQ(ierr);
+    ierr = PetscSectionSetFieldDof(coordSectionNew, v, 0, spaceDim);CHKERRQ(ierr);
   ierr = PetscSectionSetUp(coordSectionNew);CHKERRQ(ierr);
   ierr = DMSetCoordinateSection(rdm, coordSectionNew);CHKERRQ(ierr);
@@ -5396,16 +5396,16 @@ static PetscErrorCode CellRefinerSetCoordinates(CellRefiner refiner, DM dm, Pets
         ierr = PetscSectionGetOffset(coordSection, cone[v], &off[v]);CHKERRQ(ierr);
       ierr = PetscSectionGetOffset(coordSectionNew, newv, &offnew);CHKERRQ(ierr);
-      for (d = 0; d < dim; ++d) coordsNew[offnew+d] = 0.0;
-      for (v = 0; v < coneSize; ++v) {ierr = DMPlexLocalizeAddCoordinate_Internal(dm, dim, &coords[off[0]], &coords[off[v]], &coordsNew[offnew]);CHKERRQ(ierr);}
-      for (d = 0; d < dim; ++d) coordsNew[offnew+d] /= coneSize;
+      for (d = 0; d < spaceDim; ++d) coordsNew[offnew+d] = 0.0;
+      for (v = 0; v < coneSize; ++v) {ierr = DMPlexLocalizeAddCoordinate_Internal(dm, spaceDim, &coords[off[0]], &coords[off[v]], &coordsNew[offnew]);CHKERRQ(ierr);}
+      for (d = 0; d < spaceDim; ++d) coordsNew[offnew+d] /= coneSize;
       ierr = DMPlexRestoreTransitiveClosure(dm, f, PETSC_TRUE, &closureSize, &cone);CHKERRQ(ierr);
   case 2: /* Hex 2D */
   case 4: /* Hybrid Hex 2D */
     /* Cell vertices have the average of corner coordinates */
     for (c = cStart; c < cMax; ++c) {
-      const PetscInt newv = vStartNew + (vEnd - vStart) + (eMax - eStart) + (c - cStart) + (dim > 2 ? (fMax - fStart) : 0);
+      const PetscInt newv = vStartNew + (vEnd - vStart) + (eMax - eStart) + (c - cStart) + (spaceDim > 2 ? (fMax - fStart) : 0);
       PetscInt      *cone = NULL;
       PetscInt       closureSize, coneSize = 0, off[8], offnew, p, d;
@@ -5418,9 +5418,9 @@ static PetscErrorCode CellRefinerSetCoordinates(CellRefiner refiner, DM dm, Pets
       ierr = DMPlexRestoreTransitiveClosure(dm, c, PETSC_TRUE, &closureSize, &cone);CHKERRQ(ierr);
   case 1: /* Simplicial 2D */
@@ -5439,8 +5439,8 @@ static PetscErrorCode CellRefinerSetCoordinates(CellRefiner refiner, DM dm, Pets
       ierr = PetscSectionGetOffset(coordSection, cone[0], &offA);CHKERRQ(ierr);
       ierr = PetscSectionGetOffset(coordSection, cone[1], &offB);CHKERRQ(ierr);
-      ierr = DMPlexLocalizeCoordinate_Internal(dm, dim, &coords[offA], &coords[offB], &coordsNew[offnew]);CHKERRQ(ierr);
-      for (d = 0; d < dim; ++d) {
+      ierr = DMPlexLocalizeCoordinate_Internal(dm, spaceDim, &coords[offA], &coords[offB], &coordsNew[offnew]);CHKERRQ(ierr);
+      for (d = 0; d < spaceDim; ++d) {
         coordsNew[offnew+d] = 0.5*(coords[offA+d] + coordsNew[offnew+d]);
@@ -5451,7 +5451,7 @@ static PetscErrorCode CellRefinerSetCoordinates(CellRefiner refiner, DM dm, Pets
       ierr = PetscSectionGetOffset(coordSection, v, &off);CHKERRQ(ierr);
         coordsNew[offnew+d] = coords[off+d];
1.8.4.474.g128a96c
