[petsc-dev] DMPlex and scattering
Mon May 5 06:49:45 CDT 2014
On Mon, May 5, 2014 at 12:09 AM, Jed Brown <jed at jedbrown.org> wrote:
> Adrian Croucher <a.croucher at auckland.ac.nz> writes:
> > hi
> > I'm writing a finite volume test code, mostly based on the TS ex11
> > tutorial example, but in Fortran. It works ok in serial but not in
> parallel.
> > I don't really understand how the global/local scattering is done in TS
> > ex11. There don't seem to be any DMGlobalToLocalBegin() /
> > DMGlobalToLocalEnd() calls in the main RHS function routine
> > (RHSFunctionLocal_Upwind()), as there are in most of the other
> > (non-DMPlex) examples.
> DMTSSetRHSFunctionLocal registers a "local" function.  The
> global-to-local scatters are done in TSComputeRHSFunction_DMLocal().
> Matt, WTF is up with the "#if 0" crap strewn throughout this function?
That is to remind me where we will need things when we have both FV and FE
here. FE will have communication even in the RHS.
> We need Fortran interfaces for the TS functions.  SNES has Fortran
> interfaces.
Yes. I was getting to that, but first I was pulling in all the ex11 stuff
to TS utils.
  Matt
> > Presumably the setting up of ghost cells is done by the call to
> > DMPlexConstructGhostCells(). Does the ghost scattering happen in the
> > call to DMPlexInsertBoundaryValuesFVM()?
> > Unfortunately it looks like neither of these routines has a Fortran
> > interface as yet, so I can't really try them. In the meantime, I've
> > tried to do it using DMGlobalToLocalBegin() / DMGlobalToLocalEnd()
> > calls, like in the other examples, but this isn't working as yet. So I'm
> > a bit stuck. Should this approach work with DMPLex, or not?
> > Cheers, Adrian
> > Dr Adrian Croucher
> > Senior Research Fellow
> > Department of Engineering Science
> > University of Auckland, New Zealand
> > email: a.croucher at auckland.ac.nz
> > tel: +64 (0)9 923 4611
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140505/10c2ba29/attachment.html>
