[petsc-dev] [PATCH] Threadcomm: Add #include <sched.h> for cpu_set_t
Thu May 1 17:20:15 CDT 2014
A note: This issue was fixed differently in petsc-dev
https://bitbucket.org/petsc/petsc/commits/41117a8d
Satish
On Thu, 1 May 2014, Eric Bavier wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
> > BTW: were you using petsc-3.4? The code code appears to be reworked in
> > petsc-dev [and thats recommend for threads usage]
> Yes, I was building petsc-3.4.4.  The patched file looks the same in
> petsc-dev as in 3.4, though I'm sure there are other threading changes
> that could affect things.
> > Satish
> > On Thu, 1 May 2014, Satish Balay wrote:
> >> I believe this include is pulled in from pthreadclasses
> >> openmp.py as:     self.deps = [self.pthreadclasses]
> >> Is this a real dependency?
> >> If so configure should enforce this.. [Its not doing this due to the
> >> way configureLibrary() is used here]
> >> The following would be the fix.. [which gives a generic error message
> >> for pthreadclasses - this could be misleading..
> >> Did not find package PTHREADCLASSES needed by openmp.
> >> Enable the package using --with-pthreadclasses or --download-pthreadclasses
> >> $ git diff
> >> diff --git a/config/PETSc/packages/openmp.py b/config/PETSc/packages/openmp.py
> >> index a7c3fd5..b18978b 100644
> >> --- a/config/PETSc/packages/openmp.py
> >> +++ b/config/PETSc/packages/openmp.py
> >> @@ -22,6 +22,7 @@ class Configure(PETSc.package.NewPackage):
> >>    def configureLibrary(self):
> >>      ''' Checks for -fopenmp compiler flag'''
> >>      ''' Needs to check if OpenMP actually exists and works '''
> >> +    self.checkDependencies()
> >>      self.setCompilers.pushLanguage('C')
> >>      for flag in ["-fopenmp", # Gnu
> >> diff --git a/config/PETSc/packages/pthreadclasses.py b/config/PETSc/packages/pthreadclasses.py
> >> index b09e51c..08a8260 100644
> >> --- a/config/PETSc/packages/pthreadclasses.py
> >> +++ b/config/PETSc/packages/pthreadclasses.py
> >> @@ -17,6 +17,7 @@ class Configure(PETSc.package.NewPackage):
> >>      return
> >>      if not self.pthread.found:
> >>         raise RuntimeError('Pthreads not found, pthread classes needs pthreads to run')
> >>      self.found = 1
> >> But then openmp.py has the following indicating pthreadclasses is optional..
> >>     # OpenMP threadprivate variables are not supported on all platforms (for e.g on MacOS).
> >>     # Hence forcing to configure additionally with --with-pthreadclasses so that pthread
> >>     # routines pthread_get/setspecific() can be used instead.
> >>     if not self.checkCompile('#include <omp.h>\nint a;\n#pragma omp threadprivate(a)\n','') and not self.pthreadclasses.found:
> >>       raise RuntimeError('OpenMP threadprivate variables not found. Configure additionally with --with-pthreadclasses=1')
> >> Satish
> >> > I ran into a problem compiling petsc when configured with
> >> > "--with-openmp=1" on my system.  This patch seems to fix it.  Comments
> >> > welcome.
