[petsc-dev] [GPU] src/ksp/ksp/examples/tutorials/ex9 fails with mpirun -np 2
Karl Rupp rupp at iue.tuwien.ac.at
Wed Mar 26 15:35:09 CDT 2014
Hi Pierre,
 > My parallel code is really near to run using GPU device
> thanks to PETSc but I am struggling with the best way
> to fill the PETSc vectors in order in runs on CPU & GPU.
> I was using in the past, VecCreateMPIWithArray, to
> create vector but I had trouble with it on GPU.
> So I followed the example in the src/ksp/ksp/examples/tutorials/ex2.c
> and create now the vectors like this:
>    // Build x
>    ierr = VecCreate(PETSC_COMM_WORLD,&SecondMembrePetsc_); check(ierr);
>    ierr = VecSetSizes(SecondMembrePetsc_, nb_rows, nb_rows_tot);
> check(ierr);
>    ierr = VecSetFromOptions(SecondMembrePetsc_); check(ierr);
>    // Build b
>    ierr = VecDuplicate(SecondMembrePetsc_,&SolutionPetsc_);check(ierr);
> And fills it with VecSetValues function. It runs well on CPU and
> GPU but crashed only in parallel on GPU. It I use VecSet instead of
> VecSetValues, it didn't crash (but of course VecSet is not enough
> for me :-)
This sounds like exactly the problem we are now fighting for some time
now. The reason VecSet() works is that there is no MPI communication
involved, while with VecSetValues() there is MPI communication involved
to transfer values to remote ranks. Some parts of these data
distributions are not fully functional, Dominic just sent a new pull
request a few days back:
https://bitbucket.org/petsc/petsc/pull-request/138/adding-checks-for-vecscattertype/diff
> I tried to find an example to reproduce for you the problem, and I
> think src/ksp/ksp/examples/tutorials/ex9 (it is usingVecSetValues,)
> is a good one.
Thanks, I'll try to reproduce tomorrow on my CUDA-enabled machine and
will report back.
> Or did I miss something (I also try VecPlaceArray/VecRestoreArray
> but without success on GPU) ?
> Thanks, and yes you are right,  "WARNING: Using GPUs effectively is
> difficult!" :-)
One thing is to get it running - the second is to get good performance
out of it. particularly in terms of performance/Watt ;-)
Best regards,
Karli
