[petsc-dev] Jacobian lag persist with ROSW method
Jed Brown jed at jedbrown.org
Sat Mar 8 22:17:38 CST 2014
Mani Chandra <mc0710 at gmail.com> writes:
> Does linearly implicit mean that you can solve any nonlinear system with
> the ROSW methods? I set my entire system using TSSetIFunction, without any
> TSSetRHSFunction.
Yes, that is fine.  Linearly implicit means that it only solves linear
problems.  RosW methods use an (approximate) Jacobian from the beginning
of the step for all subsequent stages.
> I wanted to try the ROSW methods because the THETA methods seems to want a
> time step much much smaller than the courant time step for the nonlinear
> solver to converge.
The solver convergence is a separate problem, for which error estimators
and higher order will not help.  Work out the solver issues with beuler
before doing anything else.
> I checked the validity of the solution and it is indeed right, so the
> residual evaluation should be correct. I'm solving for the general
> relativistic mhd equations in a fixed background spacetime (kerr
> blackhole). There are large variations in the density and pressure and
> I use slope limiters.
You can try assembling a Jacobian for a first order method (no limiters)
and using TSROSW, but be very careful about stability.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140308/209bf93e/attachment.sig>
