[petsc-dev] error on MatCreateTranspose with MatSchur
Stephan Kramer s.kramer at imperial.ac.uk
Sun Mar 2 13:07:44 CST 2014
On 28/02/14 17:18, Jed Brown wrote:
> Stephan Kramer <s.kramer at imperial.ac.uk> writes:
>> Dear petsc devs,
>> Building our code against today's 'master', I came across the following error that worked fine with petsc 3.4.
> I believe this is fixed in 'next'.  If you check there, I'll merge it to
> 'master'.
Great. That fixes it indeed
Cheers
Stephan
