[petsc-dev] [petsc-users] gamg failure with petsc-dev
Stephan Kramer s.kramer at imperial.ac.uk
Thu Jul 31 09:44:01 CDT 2014
An update on this. We have been using mark/gamg-zerod branch and it
fixes for us the issue with zero diagonals in the coarsened operators
(making the sor smoother, but bizarrely not the jacobi smoother fail).
We in fact have some cases where cheby+jacobi does not converge
(indefinite pc), but cheby+sor (with the mark/gamg-zerod branch) works
well, so we'd be very much interested in getting this (or something
similar) merged in master. Maybe the lv[i-Istart]==0.0 thing isn't
entirely robust? We'd be happy to contribute.
As an aside, we also changed the ordering of DOFs as suggested, so that
we provide the right block structure to gamg. However, as soon as we
actually set the block size (MatSetBlockSizes) the convergence
deteriorates substantially (going from ~50 to ~650 iterations). Without
setting the block size but with the new ordering, the n/o iterations is
roughly the same as before (when our dofs were not interlaced). Any idea
what might be going wrong?
Cheers
Stephan
On 01/04/14 19:17, Jed Brown wrote:
> Stephan Kramer <s.kramer at imperial.ac.uk> writes:
>> Yes indeed. I've come to realize this now by looking into how smoothed
>> aggregation with a near null space actually works. We currently have
>> our dofs numbered the wrong way around (vertices on the inside,
>> velocity component on the outside - which made sense for other eqns we
>> solve with the model) so will take a bit of work, but might well be
>> worth the effort
> The memory streaming and cache reuse is much better if you interlace the
> degrees of freedom.  This is as true now as it was at the time of the
> PETSc-FUN3D papers.  When evaluating the "physics", it can be useful to
> pack the interlaced degrees of freedom into a vector-friendly ordering.
> The AMG solve is plenty expensive that you can pack/solve/unpack an
> interlaced vector at negligible cost without changing the rest of your
> code.
> Mark, should we provide some more flexible way to label "fields"?  It
> will be more complicated than the present code and I think packing into
> interlaced format is faster anyway.
