[petsc-dev] KSPComputeExtremeSingularValues_GMRES floating point exception
Wed Jul 23 16:11:09 CDT 2014
On Jul 23, 2014, at 9:54 AM, John Mousel <john.mousel at gmail.com> wrote:
> I'm getting an FPE in LAPACKgesvd of KSPComputeExtremeSingularValues_GMRES.
  ierr = PetscFPTrapPush(PETSC_FP_TRAP_OFF);CHKERRQ(ierr);
#if !defined(PETSC_USE_COMPLEX)
  PetscStackCallBLAS("LAPACKgesvd",LAPACKgesvd_("N","N",&bn,&bn,R,&bN,realpart,&sdummy,&idummy,&sdummy,&idummy,work,&lwork,&lierr));
#else
  PetscStackCallBLAS("LAPACKgesvd",LAPACKgesvd_("N","N",&bn,&bn,R,&bN,realpart,&sdummy,&idummy,&sdummy,&idummy,work,&lwork,realpart+N,&lierr));
#endif
  if (lierr) SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_LIB,"Error in SVD Lapack routine %d",(int)lierr);
  ierr = PetscFPTrapPop();CHKERRQ(ierr);
  What version of PETSc are you using? In our current release we turn off the trapping for that routine but maybe yours is a system that cannot turn it off
> I'm not sure where this routine is required during the algorithm as I'm using BiCG + richardson/SOR on all multigrid levels.
   Good question. Yes it would normally not use the KSPComputeExtremeSingularValues_GMRES() Is there more error message that shows where the functions are called from?
> Also, even though I've set mg_coarse_ksp_type richardson, KSPView is showing that preonly is used on the coarsest level. Am I misunderstanding something about the options I'm using?
    They seem to be correct. If you run with -options_left does it indicate that option is never used?
   Suggest upgrading to PETSc 3.5
   Barry
> -pres_ksp_type preonly -pres_pc_type redistribute -pres_redistribute_ksp_type bcgsl -pres_redistribute_pc_type gamg -pres_redistribute_pc_gamg_threshold 0.01 -pres_redistribute_mg_levels_ksp_type richardson -pres_redistribute_mg_levels_pc_type sor -pres_redistribute_mg_coarse_ksp_type richardson -pres_redistribute_mg_coarse_pc_type sor -pres_redistribute_mg_coarse_pc_sor_its 4 -pres_redistribute_pc_gamg_agg_nsmooths 1 -pres_redistribute_pc_gamg_sym_graph true -pres_redistribute_gamg_type agg -pres_ksp_view
> [8]PETSC ERROR: ------------------------------------------------------------------------
> [8]PETSC ERROR: Caught signal number 8 FPE: Floating Point Exception,probably divide by zero
> [8]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [8]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[8]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
> [40]PETSC ERROR: ------------------------------------------------------------------------
> [40]PETSC ERROR: Caught signal number 8 FPE: Floating Point Exception,probably divide by zero
> [40]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [40]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[40]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
> [40]PETSC ERROR: likely location of problem given in stack below
> [40]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
> [40]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [40]PETSC ERROR:       INSTEAD the line number of the start of the function
> [40]PETSC ERROR:       is given.
> [40]PETSC ERROR: [40] LAPACKgesvd line 42 /Users/jmousel/SOFT/petsc/src/ksp/ksp/impls/gmres/gmreig.c
> [40]PETSC ERROR: [40] KSPComputeExtremeSingularValues_GMRES line 24 /Users/jmousel/SOFT/petsc/src/ksp/ksp/impls/gmres/gmreig.c
> [40]PETSC ERROR: [40] KSPComputeExtremeSingularValues line 51 /Users/jmousel/SOFT/petsc/src/ksp/ksp/interface/itfunc.c
> KSP Object:proj_ksp(pres_) 96 MPI processes
>   type: preonly
>   maximum iterations=1000, initial guess is zero
>   tolerances:  relative=1e-50, absolute=0.01, divergence=10000
>   left preconditioning
>   using NONE norm type for convergence test
> PC Object:(pres_) 96 MPI processes
>   type: redistribute
>       Number rows eliminated 7115519 Percentage rows eliminated 44.1051
>     Redistribute preconditioner:
>   KSP Object:  (pres_redistribute_)   96 MPI processes
>     type: bcgsl
>       BCGSL: Ell = 2
>       BCGSL: Delta = 0
>     has attached null space
>     using PRECONDITIONED norm type for convergence test
>   PC Object:  (pres_redistribute_)   96 MPI processes
>     type: gamg
>       MG: type is MULTIPLICATIVE, levels=4 cycles=v
>         Cycles per PCApply=1
>         Using Galerkin computed coarse grid matrices
>     Coarse grid solver -- level -------------------------------
>       KSP Object:      (pres_redistribute_mg_coarse_)       96 MPI processes
>         type: preonly
>         maximum iterations=1, initial guess is zero
>         tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>       PC Object:      (pres_redistribute_mg_coarse_)       96 MPI processes
>         type: sor
>           SOR: type = local_symmetric, iterations = 4, local iterations = 1, omega = 1
>         linear system matrix = precond matrix:
>         Mat Object:         96 MPI processes
>           type: mpiaij
>           rows=465, cols=465
>           total: nonzeros=84523, allocated nonzeros=84523
>           total number of mallocs used during MatSetValues calls =0
>             not using I-node (on process 0) routines
>     Down solver (pre-smoother) on level 1 -------------------------------
>       KSP Object:      (pres_redistribute_mg_levels_1_)       96 MPI processes
>         type: richardson
>           Richardson: damping factor=1
>         maximum iterations=2
>         using nonzero initial guess
>       PC Object:      (pres_redistribute_mg_levels_1_)       96 MPI processes
>         type: sor
>           SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1
>           type: mpiaij
>           rows=13199, cols=13199
>           total: nonzeros=2.09436e+06, allocated nonzeros=2.09436e+06
>     Up solver (post-smoother) same as down solver (pre-smoother)
>     Down solver (pre-smoother) on level 2 -------------------------------
>       KSP Object:      (pres_redistribute_mg_levels_2_)       96 MPI processes
>         type: richardson
>       PC Object:      (pres_redistribute_mg_levels_2_)       96 MPI processes
>         type: sor
>           type: mpiaij
>           rows=568202, cols=568202
>           total: nonzeros=2.33509e+07, allocated nonzeros=2.33509e+07
>     Down solver (pre-smoother) on level 3 -------------------------------
>       KSP Object:      (pres_redistribute_mg_levels_3_)       96 MPI processes
>         type: richardson
>       PC Object:      (pres_redistribute_mg_levels_3_)       96 MPI processes
>         type: sor
>           type: mpiaij
>           rows=9017583, cols=9017583
>           total: nonzeros=1.01192e+08, allocated nonzeros=1.01192e+08
>       type: mpiaij
>   Mat Object:  proj_A   96 MPI processes
>     type: mpiaij
>     rows=16133102, cols=16133102
>     total: nonzeros=1.09807e+08, allocated nonzeros=1.57582e+08
>   Residual norms for vel_ solve.
