[petsc-dev] git workflow question
Dominic Meiser dmeiser at txcorp.com
Fri Jul 18 11:10:12 CDT 2014
On 07/18/2014 09:51 AM, Matthew Knepley wrote:
> On Fri, Jul 18, 2014 at 10:58 AM, Dominic Meiser <dmeiser at txcorp.com
> <mailto:dmeiser at txcorp.com>> wrote:
>     I'm starting development of a bug fix in a new feature branch. The
>     bug fix heavily relies on work in a different feature branch which
>     is still a long ways away from getting merged into next or master.
>     Which of the following approaches is the recommended practice:
>     1) Branch off of master and merge the other feature branch I need
>     into the newly create branch.
>     2) Branch off of the other feature branch.
>     3) Something else I'm not thinking of.
> I do not really understand why you just do not make the fix in the
> feature branch?
To make things more specific, the bug fix is for DMDA's with cusp
vectors. I think this will be a fair amount of work and it may take a
while to complete. It needs work I've done in the
dmeiser/fix-cusp-bjacobi branch but is otherwise unrelated. I thought it
might be good to do it in a separate branch because of that. I wouldn't
want work on this bug fix to hold up things with fix-cusp-bjacobi or to
make that branch more difficult to review.
Cheers,
Dominic
>    Matt
>     Thanks.
>     Dominic
>     Dominic Meiser
>     Tech-X Corporation
>     5621 Arapahoe Avenue
>     Boulder, CO 80303
>     USA
>     Telephone: 303-996-2036 <tel:303-996-2036>
>     Fax: 303-448-7756 <tel:303-448-7756>
>     www.txcorp.com <http://www.txcorp.com>
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
Dominic Meiser
Tech-X Corporation
Boulder, CO 80303
USA
Fax: 303-448-7756
www.txcorp.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140718/f6094f26/attachment.html>
