[petsc-dev] Error reported by MUMPS in numerical factorization phase: INFO(1)=-100, INFO(2)=-32766
Nathan Collier nathaniel.collier at gmail.com
Mon Jul 14 21:57:32 CDT 2014
Robert,
Sections 6 and 7 of the MUMPS user manual here (
http://mumps.enseeiht.fr/doc/userguide_4.10.0.pdf) explains those info
messages. Unfortunately, I do not see an explanation of the INFO values you
report. Doesn't seem to explain the problem but might point you in the
right direction.
Nate
On Mon, Jul 14, 2014 at 8:39 PM, Robert Simon <rsimon at us.ibm.com> wrote:
> Hello,
>   Does anyone know what this failure means and how to solve it?
>   It only seems to occur when I run PETSC with IBM POE's MPI.  If I run
> with the INTEL mpirun, I do not see the
> failure.
> Best regards,
>   Bob Simon
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140714/6b2bc4a4/attachment.html>
