[petsc-dev] petsc4py, TAO, and complex scalars
Fri Jul 11 13:46:25 CDT 2014
On Fri, 11 Jul 2014, Barry Smith wrote:
> On Jul 11, 2014, at 1:29 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > Yeah - I had merged this branch to next to test it out.  Lisandro is
> > on travel - so might not be checking e-mails.
> > Perhaps tao/complex build should be enabled only for c99/complex..
>    Are all the failures only for C++ complex?
yes. [and Lisandro and I might have checked just the c/complex builds locally]
>  How easy/hard would they be too fix. In the long run just getting tao complex clean would make our lives simpler.
I'll have to check.
Satish
>    Barry
> > Satish
> >>   There are a truck load of complex related errors in tao in next: http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2014/07/10/filtered-make_next_arch-freebsd-cxx-cmplx-pkgs-dbg_wii.log  see also the other complex builds at http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2014/07/10/next.html
> >>  not sure if they are related to your change
> >>   Barry
> >> On Jul 8, 2014, at 8:57 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> >>> On 8 July 2014 15:16, Matthew Knepley <knepley at gmail.com> wrote:
> >>>> On Tue, Jul 8, 2014 at 2:09 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> >>>>> Some time ago I merged tao4py in petsc4py following PETSc. Now I
> >>>>> realize that TA0 is not available for --with-scalar-type=complex, all
> >>>>> of the TAO API is not built. Adding support for this case in petsc4py
> >>>>> will be rather involved, so I want to propose an alternative.
> >>>>> I have a rather small patch that enables the compile of interface TAO
> >>>>> APIs.  With this patch, I can build petsc4py, but obviously any
> >>>>> attempt of use a specific TAO solver type fails at runtime because the
> >>>>> solve implementations are not registered. But at least, petsc4py can
> >>>>> be built with complex scalars and all other PETSc components can be
> >>>>> used normally.
> >>>>> What do you think? If you accept this proposal, I'll put all this in a
> >>>>> branch for review. Additionally, I would like to merge this fix into
> >>>>> maint.
> >>>> That sounds fine to me. We will fix this for the next release, so it would
> >>>> just hang around until then.
> >>> https://bitbucket.org/petsc/petsc/branch/dalcinl/tao-complex_scalars
> >>> This hook is a hack, but seems the easiest way to support complex scalars:
> >>> https://bitbucket.org/petsc/petsc/commits/a62a097f5bb5c39fb23ca6e1f9f37f7c197bfa6d?at=master#Lsrc/tao/matrix/lmvmmat.cT5
> >>> Please review,
> >>> Lisandro Dalcin
> >>> CIMEC (UNL/CONICET)
> >>> Predio CONICET-Santa Fe
> >>> Colectora RN 168 Km 472, Paraje El Pozo
> >>> 3000 Santa Fe, Argentina
> >>> Tel: +54-342-4511594 (ext 1016)
> >>> Tel/Fax: +54-342-4511169
