[petsc-dev] petsc4py, TAO, and complex scalars
Tue Jul 8 07:16:27 CDT 2014
On Tue, Jul 8, 2014 at 2:09 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> Some time ago I merged tao4py in petsc4py following PETSc. Now I
> realize that TA0 is not available for --with-scalar-type=complex, all
> of the TAO API is not built. Adding support for this case in petsc4py
> will be rather involved, so I want to propose an alternative.
> I have a rather small patch that enables the compile of interface TAO
> APIs.  With this patch, I can build petsc4py, but obviously any
> attempt of use a specific TAO solver type fails at runtime because the
> solve implementations are not registered. But at least, petsc4py can
> be built with complex scalars and all other PETSc components can be
> used normally.
> What do you think? If you accept this proposal, I'll put all this in a
> branch for review. Additionally, I would like to merge this fix into
> maint.
That sounds fine to me. We will fix this for the next release, so it would
just hang around until then.
   Matt
> Lisandro Dalcin
> CIMEC (UNL/CONICET)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> 3000 Santa Fe, Argentina
> Tel: +54-342-4511594 (ext 1016)
> Tel/Fax: +54-342-4511169
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140708/b7ab7a4b/attachment.html>
