[petsc-dev] PETSc 3.5.0 compilation on Windows and OpenMP with pthread
Thu Jul 3 12:36:35 CDT 2014
I'll be disabling these in petsc-3.5 [patch update]
Are you sure you need to use 'next' - and not 'master'?
[sorry I don't remember the discussion on why you needed next]
Satish
On Thu, 3 Jul 2014, Dave Nystrom wrote:
> So what exactly do you mean when you say to turn off the support for the
> current pthreads support because I have been using it, such as it is, in
> the next branch?
> > -------- Original Message --------
> > Subject: Re: [petsc-dev] PETSc 3.5.0 compilation on Windows and OpenMP
> > with pthread
> > From: Barry Smith <bsmith at mcs.anl.gov>
> > Date: Thu, July 03, 2014 10:08 am
> > To: Jed Brown <jed at jedbrown.org>
> > Cc: "petsc-dev at mcs.anl.gov" <petsc-dev at mcs.anl.gov>
> > On Jul 3, 2014, at 8:37 AM, Jed Brown <jed at jedbrown.org> wrote:
> > > Satish Balay <balay at mcs.anl.gov> writes:
> > >> threadcomm.py is disabled in petsc3.4, 3.5. Should pthreadclasses.py also be
> > >> disabled? [should openmp.py also be disabled?]
> > >> https://bitbucket.org/petsc/petsc/commits/6e5884b57154c4018286842049a07306848380f9#chg-config/PETSc/packages/threadcomm.py
> > > Yes, they can't do anything but cause confusion right now, and the
> > > legacy "pthreadclasses" option should go away.
> >    Yes turn them all off.
