[petsc-dev] PETSc 3.5.0 compilation on Windows and OpenMP with pthread
Jed Brown jed at jedbrown.org
Thu Jul 3 08:48:33 CDT 2014
Baros Vladimir <vbaros at hsr.ch> writes:
> So it could be that the external packages were using OpenMP because
> compiled applications from my build require an openmp dll.
Are you using --download for them?  Why does PETSc need to be built with openmp?
> With this build I compiled a static version of pthreads-win32 from here:
> https://www.sourceware.org/pthreads-win32/
> and PETSc compiled with those libs. Also configuration stage passed without problems.
> But at the end the tests failed with the unresolved PetscThreadCommCreate_PThread
The options --with-pthread, --with-pthreadclasses, and --with-openmp are
not orthogonal in the current version (i.e., the preprocessor macros do
not support all the combinations).  It doesn't make sense to "fix"
because we're refactoring in a significant way and the current version
is too fragile about issues like affinity.  Just don't use any of it
right now.  External packages are welcome to use OpenMP and I expect
we'll have the better system out by the end of summer.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140703/d235ba55/attachment.sig>
