[petsc-dev] PetscMalloc for size zero
Thu Jan 30 13:01:06 CST 2014
On Thu, Jan 30, 2014 at 12:50 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jan 30, 2014 at 12:46 PM, Brad Aagaard <baagaard at usgs.gov> wrote:
>> On 01/30/2014 10:34 AM, Jed Brown wrote:
>>> Brad Aagaard <baagaard at usgs.gov> writes:
>>>  Matt and Jed,
>>>> I see that Jed pushed some changes (jed/malloc-zero) for PetscMalloc to
>>>> deal with memory alignment and a zero size. It looks like the pointer
>>>> will NOT be NULL for a size of 0. Is this true?
>>> Yes, just like malloc(), it can be either a unique pointer or NULL.  You
>>> need the size anyway to know how many elements are in the array.
>> I thought it was a nice feature that PETSc improved on malloc() and
>> free() by returning NULL for zero sized allocation (although this wasn't
>> true for --with-debugging=0 due to memory alignment) and set pointers to
>> NULL after freeing.
>> What is the rationale for not returning NULL for mallocs of size zero
>> other than conforming to C malloc behavior?
> There is no such thing as "conforming to C malloc", since that WOULD allow
> returning NULL in this case.
Actually, we are violating the malloc standard that Jed sent out. It says
that for 0 size, malloc must return
  NULL or a unique pointer
However, if we have
  PetscMalloc2(0,&r1,1,&r2)
then r1 == r2 with the optimized implementation, and the pointers are not
unique.
   Matt
> I think we are doing users a disservice by not enforcing this.
>    Matt
>> Brad
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140130/c2510e90/attachment.html>
