[petsc-dev] configure failed after update of OSX
Jed Brown jed at jedbrown.org
Wed Jan 29 06:10:58 CST 2014
[You should be aware that your message didn't set In-Reply-To or
References, thus doesn't thread correctly.  Please check your mailer
settings.]
Åsmund Ervik <asmund.ervik at ntnu.no> writes:
>>From: Satish Balay <balay at mcs.anl.gov>
>>To: Jed Brown <jed at jedbrown.org>
>>Cc: petsc-dev <petsc-dev at mcs.anl.gov>
>>Subject: Re: [petsc-dev] configure failed after update of OSX
>>Our linux compute machines [ubuntu 12.04] is also has  3.81
>>Fedora Linux is still at 3.82
>>http://koji.fedoraproject.org/koji/packageinfo?packageID=813
> ArchLinux (which is bleeding edge and rolling release) only upgraded
> to 4.0 in October.
4.0 was released Oct 9; I don't blame any system for not having upgraded
yet.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140129/fd8a5c73/attachment.sig>
