[petsc-dev] configure failed after update of OSX
    Sean Farley
    sean.michael.farley at gmail.com
    Tue Jan 28 19:35:43 CST 2014
balay at mcs.anl.gov writes:
> On Tue, 28 Jan 2014, Sean Farley wrote:
>> >> > I'm not sure how this is causing gmake 'internal' error..
>> >> It doesn't necessarily mean that gmake is broken but could be something
>> >> mismatched. I can't tell without the internal logs.
>> >> Though, I recommend that Mark not use any --download options through
>> >> petsc because those packages are now in MacPorts and mixing two stacks
>> >> is just asking for trouble.
>> > So - unless Mark is also using 'macports' install of PETSc - he is
>> > asking for trouble?
>> No.
> Ok - you mean - "if Mark has superlu_dist installed by macports - and
> also uses --download-superlu_dist - then he will have 2 copies of
> superlu_dist - and the configure might test for one of the installs
> [during configure state] - but the linker can pick up the other one
> [based on the order of -L paths added by configure] - and cause wierd
> link/runtime errors."
> I agree that a problem - and we've seen it before. The fix is to have
> only install of such package [either via --download-package or from
> macports - but not have both installs]
Yes, this is no doubt a common problem.
> We've also had this issues with folks having blas/lapack, X11 packages
> installed in both system location & macports.
Yes, ATLAS being installed is mostly a nightmare. I now have it
installed solely to fix linking issues.
