[petsc-dev] configure failed after update of OSX
Sean Farley sean.michael.farley at gmail.com
Tue Jan 28 19:34:23 CST 2014
balay at mcs.anl.gov writes:
> On Tue, 28 Jan 2014, Sean Farley wrote:
>> The gmake issue could be a lot of things:
>> - something weird with mpich's autoconf
>> - libtool problems
>> - gmake itself
>> - path issues
> The issue is with 'gmake - j 7 all' with mpich build [and similarly
> petsc build] after configure [of the corresponding package] is
> completed.
So I see. I still can't reproduce but it seems that other gmake users
have this issue on case-insensitive filesystems (which I don't
have). Can you reproduce this on a vm easily? It'd be great to nail this
down.
>> I'll try to reproduce this again to see if it happens on my machine.
>> Maybe I should just advise not to use --download-*mpi*. Wrapping
>> compilers is tricky. For example, Mark seems to have upgraded to
>> Mavericks, yet in his script he is specifying gcc/g++ which is no longer
>> distributed with Xcode.
> Apple [Xcode5] provides a binary called /usr/bin/gcc - which is
> 'clang'.  [Yeah naming 'clang' as 'gcc' is funky - but I think apple
> does that to not break user makefiles that have 'gcc' hardcoded]
Ah, right, I forgot. Confusing, nonetheless.
