[petsc-dev] configure failed after update of OSX
Sean Farley sean.michael.farley at gmail.com
Tue Jan 28 18:52:43 CST 2014
balay at mcs.anl.gov writes:
>> >> mfadams at lbl.gov writes:
>> >> > Oh yes.  I had a use-make=make commended out. I uncommented it and its
>> >> > seems to have gotten MPICH installed.
>> >> There is a newly (only a few days old) updated mpich port that I now use
>> >> with my petsc install.
>> > This is not really a fix - as the 'gmake' error will pop up with petsc
>> > part of the build aswell.
>> False. It works perfectly fine here.
> That doesn't mean it woud work for Mark. Previously [a few months
> back] Mark had the same issue - and you've responded that you couldn't
> reproduce it.
>> >> > On Tue, Jan 28, 2014 at 1:26 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> >> >> I'll have to check back my e-mail archive - but I think
>> >> >> '/opt/local/bin/gmake' is broken. Don't you have /usr/bin/make?
>> >> >> I thought petsc configure prefred /usr/bin/make - if it was found.
>> >> >> One more -ve for macports..
>> >> There is a fundamental problem with using two stacks. Similar, I think,
>> >> to trying to simultaneously link to libc++ and libstdc++. It is just
>> >> asking for trouble.
>> > I'm not sure how this is causing gmake 'internal' error..
>> It doesn't necessarily mean that gmake is broken but could be something
>> mismatched. I can't tell without the internal logs.
>> Though, I recommend that Mark not use any --download options through
>> petsc because those packages are now in MacPorts and mixing two stacks
>> is just asking for trouble.
> So - unless Mark is also using 'macports' install of PETSc - he is
> asking for trouble?
No.
> [otherwise he can easily end up mixing these
> exteranlpackages from macports - and build petsc with native OSX
> compilers - so will end up mixing stack anyway?]
The gmake issue could be a lot of things:
- something weird with mpich's autoconf
- libtool problems
- gmake itself
- path issues
I'll try to reproduce this again to see if it happens on my machine.
Maybe I should just advise not to use --download-*mpi*. Wrapping
compilers is tricky. For example, Mark seems to have upgraded to
Mavericks, yet in his script he is specifying gcc/g++ which is no longer
distributed with Xcode.
For my own work, I install the Apple clang + gfortran 4.8 most of the
time, via
$ sudo port install mpich-default
$ sudo port select --set mpi mpich-mp-fortran
Then try to build PETSc (minus the --download-mpich and CC, CXX, FC
options). You could also try to install most of the external packages:
$ sudo port install hypre ml parmetis metis hdf5-18 netcdf triangle \
superlu superlu_dist mumps
ctetgen and exodusii aren't in MacPorts but (assuming the licenses allow
it) I could add them.
