[petsc-dev] configure failed after update of OSX
Tue Jan 28 14:01:41 CST 2014
Yeah --with-make=/usr/bin/make is the workarround.
I'll have to recheck why gmake is prefered over /usr/bin/make. [I
thought I fixed that].
Also can you check if --download-make works or breaks similarly?
Satish
On Tue, 28 Jan 2014, Mark Adams wrote:
> Oh yes.  I had a use-make=make commended out. I uncommented it and its
> seems to have gotten MPICH installed.
> On Tue, Jan 28, 2014 at 1:26 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > I'll have to check back my e-mail archive - but I think
> > '/opt/local/bin/gmake' is broken. Don't you have /usr/bin/make?
> > I thought petsc configure prefred /usr/bin/make - if it was found.
> > One more -ve for macports..
> > Satish
> > TEST configureMake from
> > config.packages.make(/Users/markadams/Codes/petsc/config/BuildSystem/config/packages/make.py:61)
> > TESTING: configureMake from
> > config.packages.make(config/BuildSystem/config/packages/make.py:61)
> >   Check for user specified make - or gmake, make
> > Checking for program /opt/local/bin/gmake...found
> >           Defined make macro "MAKE" to "/opt/local/bin/gmake"
> > gmake[2]: *** read jobs pipe: No such file or directory.  Stop.
> > gmake[2]: *** Waiting for unfinished jobs....
> > gmake[2]: *** write jobserver: Broken pipe.  Stop.
> > gmake[1]: *** [all-recursive] Error 1
> > gmake: *** [all] Error 2
> > gmake: INTERNAL: Exiting with 1 jobserver tokens available; should be 7!
> > > I managed to get macports to rebuild.  It was not that hard as it turns
> > > out, I was just confused about exactly what to do.  GDB broke but I was
> > > able to install it after macports updated outdated packages.  PETSc still
> > > seem to fail in MPICH, however.
> > > On Tue, Jan 28, 2014 at 12:54 PM, Matthew Knepley <knepley at gmail.com>
> > wrote:
> > > > On Tue, Jan 28, 2014 at 12:51 PM, Jed Brown <jed at jedbrown.org> wrote:
> > > >> Satish Balay <balay at mcs.anl.gov> writes:
> > > >> > I agree a better package management system [aka macports/homebrew]
> > > >> > should be preferable. But with all the wierd issues that keep
> > comping
> > > >> > up with users using macports on petsc lists - I can't convince
> > myself
> > > >> > that it is a better recommendation.
> > > >> People either need a reliable way to upgrade or the stack will get out
> > > >> of date.  Also, system upgrades will be stop-the-world events with
> > > >> unknown system changes and the only safe thing is to reinstall the
> > > >> entire stack.  Very few people can remember all the installation
> > quirks
> > > >> they have gone through, and even then, it takes time to reinstall
> > > >> everything.
> > > > This is largely ideology. Some of us have used OSX for development for
> > > > years
> > > > with little productivity impact.
> > > >   Matt
> > > >>  > I would aswell recommend virtualbox with linux as a superior
> > choice.
> > > >> I recommend
> > > >>   # dd if=/dev/zero of=/dev/disk0
> > > >> and install a decent operating system with a package manager on your
> > > >> now-impeccably-clean disk.
> > > > What most experimenters take for granted before they begin their
> > > > experiments is infinitely more interesting than any results to which
> > their
> > > > experiments lead.
> > > > -- Norbert Wiener
